LT1 cam for my 350 TPI
Old 07-11-2010, 03:40 PM
IROCZTPI's Avatar
Default LT1 cam for my 350 TPI
This is my 1st post on this site but I've been reading the threads on here for along time. I'm a member on thirdgen.org but recently I decided that the site is not very helpful when it comes to asking a question. Here are a few questions/comments I have for you guys.
Here's my plan:
I'm thinking about buying the LT1 cam from a 93 Camaro Z28 LT1. I found one for $25 on Craigslist. He's also got the aluminum heads ready to bolt on with the rockers, roller lifters, push rods, pistons and rods ready to install and flywheel. The prices on the other stuff isn't bad. The heads are $200, the most expensive of all. Then my other question is would these parts interchange well with the Holley Stealth Ram Intake set-up? I'm buying this also because I need to upgrade my TPI intake piece along with with fuel rails, etc.
I think I also need to do some chip burning for the LT1 cam correct?
Well, I wanted to ask you guys how hard it'll be to put the cam alone in my TPI? I've already got a cam in my car but it was put in by a former owner so I'm thinking of just doing my own switch.
I figured this would be the place to ask & also, I'm very mechanically inclined and I do alot of work myself, so I'm hoping this could be something that I could do with myself, a friend or 2 and a some jacks.
Thank you.
Old 07-11-2010, 06:19 PM
RamAir95TA's Avatar
LT1 heads won't work with your conventional gen 2 SBC due to the reverse flow cooling.
The cam, however, will.
Old 07-11-2010, 06:21 PM
IROCZTPI's Avatar
Would the other stuff work such as the roller lifters for example? The heads I knew would require some modifications that I don't want to deal with. I found out after I posted this thread earlier.
Old 07-11-2010, 06:23 PM
RamAir95TA's Avatar
I would think that the lifters and everything else would work, but I'm not a TPI guy. Just double-check.
Old 07-11-2010, 08:11 PM
IROCZTPI's Avatar
Yeah, I'm working on trying to find out right now.
Old 07-11-2010, 08:31 PM
joelster's Avatar
If your IROC is an original 350 IROC then it was 1987 and up. All '87+ TPI motors were roller cammed so yes the cam in an LT1 will bolt right up. What a collosal waste of time though. A stock LT1 cam is by no means a performance camshaft. Actually iirc the 1989 305 TPI IROC cam has more lift and duration than an LT1 cam. I will check real quick and get back. If you are going to swap a camshaft make it worth your while. Get those junk L98 heads off and find something better that doesn't break the budget.
1987 TPI 350 camshaft specs:
202/207 .404/.415
1989 TPI 305 M5 camshaft specs:
207/213 .415/.430
1993 LT1 camshaft specs:
205/207 .447/.459
*edit, the 305 cam has more duration but less lift.
Old 07-11-2010, 08:42 PM
BlackBird87's Avatar
You should be looking into A. porting the plenum and slp runners. Or B. using an lt1 manifold. The stock intake is a joke
Old 07-11-2010, 10:17 PM
IROCZTPI's Avatar
I already have a great set of AS&M intake runners over the old stock ones & the intake manifold I'm buying is the Holley Stealth Ram with new fuel rails and an adjustable fuel pressure regulator.
Once I have the Holley intake I won't need the AS&M runners anymore, how ironic that'll be.
Old 07-11-2010, 10:19 PM
IROCZTPI's Avatar
202/207 .404/.415
207/213 .415/.430
205/207 .447/.459
I hear you. There's an aftermarket cam in my car now, with the valve springs and other internal work done but I don't know the brand. I just want to do my OWN cam swap and other internal swapping and not keep the other stuff the former owner(s) did. I'm the 5th owner but I intend on being the last.
If the LT1 isn't worth the hassle which I was afraid it wouldn't be then I'll look for something else. I won't put one in until I have the Holley ram intake installed with the adjustable FPR and fuel rails installed 1st. Then I'd have the other stuff done and right now I'm looking, researching & preparing for the buy.
Old 07-11-2010, 11:15 PM
I heard very good things about the stealth ram not cheap tho. I know where youre coming from wanting to do your own mods and all but for all you know you might have a really good cam it there now. I would install the new intake and see what it feels like then
Old 07-11-2010, 11:24 PM
IROCZTPI's Avatar
You're right. Want to know the funny thing regarding the price on this Stealth Ram Intake?
On one website it's $450+ dollars not including the tax and shipping fee.
On the Holley website itself the Stealth Ram is only $354 + tax but shipping is free.
So that's kind of weird that there is a $100+ price difference from the actual vendor and a F-Body website that sells the same product. One of the good things I've heard alot about the Holley Ram Intake is that you'll gain a good 40-60 horsepower to the wheels, depending on the kind of car you have and all. That's not surprising either. I can't wait to get rid of my TPI intake manifold and fuel rails.
Old 07-11-2010, 11:31 PM
Thats why is always pays to shop around. I think 40-60 at the wheels at the wheels is a lil high but its going to be a night and day difference at 4k and up. Thats right where my tpi would stop pulling hard. Not to mention the pain in the *** it is to put off the runners and get to the injectors
Old 07-11-2010, 11:37 PM
3.8redbird's Avatar
the HSR is the best money I have spent on my car. Mine is a fully customized unit from a third party (PM for details). If you look at my numbers my setup works pretty well.
If you plan on owning the car for a long time do it right the first time. If I could go back AFR 195 heads would be sitting on it instead of the Dart iron eagles.
As for tuning you will need it for the intake aswell. I suggest doing all the mods at once. My cam would be good in a 350. Its on the small side for a 383
Old 07-11-2010, 11:46 PM
IROCZTPI's Avatar
Correct. Well, I've gotta figure out what heads to get to go with the HSR Intake because I won't have runners anymore & I want to replace ALL of my internal stuff at the same time (but I'm buying everything at different times since I don't have the money all at once).
Old 07-11-2010, 11:49 PM
IROCZTPI's Avatar
The Holley website quotes it (or is it the other F-Body site) that the HSR Intake provides anywhere from 30-60 rwhp. Not 40-60. My bad. My IROC stock would fall on it's face at around 4,200 RPM. It doesn't lose breath until around 5,200-5,500 RPM.
I've read some post's on other sites regarding the intake and it's gotten alot of praise for being a good set-up on the L98 with better upper-end power too. I might lose a little bit at the bottom but the overall powerband is better than the TPI intake even with my mild cam.
Old 07-11-2010, 11:52 PM
youre on the right track do your research and youll be pleased with the results, check out thirdgen.org if you already haven't
Old 07-12-2010, 12:00 AM
IROCZTPI's Avatar
Oh, I've been a member on that site for over a year now, but I'm sort of tired of that site because nobody ever answers a question that I rarely ask.
But I found a set of Chevy Vortec 906 heads that are COMPLETE with everything and I am trying to figure out if those would work on my car. I'm still looking into it but a guy is trying to sell these that were in a 1500 Chevy 350 truck for $200.
Old 07-12-2010, 12:05 AM
It is a lil hit or miss on there. I cant remember if they worked or not. i know they bolt up to the block but i dont know about the intake
Old 07-12-2010, 12:11 AM
IROCZTPI's Avatar
I've been reading arguments between car guys regarding the 062 and 906 Vortec heads and what flows better. I think I'm going to keep looking.
Old 07-12-2010, 01:27 AM
3.8redbird's Avatar
They flow to 62-6500rpm on a 350. I have my rev limiter set at 5200rpm and it wants to pull like crazy. Mine being a bigger engine I would hope for 58-6000rpm peak.
Once I blow my engine I will build one to spin to 6500+ and see what the intake really can do. But mine is fully ported except port matching to heads since I plan on AFRs down the road
Quick Reply: LT1 cam for my 350 TPI
