Can you convert a corvette trans into a camaro trans?
Old 07-05-2010, 04:14 PM
-DLS-'s Avatar
Default Can you convert a corvette trans into a camaro trans?
The corvette trans is double ended.
Can you just simply unsrew the housing at the end and it looks like a normal trans or no?
I found a cheap T56 MN6 and I'm wondering if I can stick it into my camaro without a lot of work?
Anyone done this?
Old 07-05-2010, 04:33 PM
thesource's Avatar
Its been done but need several parts to convert it.
Old 07-05-2010, 05:48 PM
85MikeTPI's Avatar
You can convert it to a SSR-hybrid:
http://www.eecis.udel.edu/~davis/z28..._Fbody_T56.pdf
Or more easily into a GTO-hybrid. The GTO-hybrid will use some of the same ideas/costs of the SSR-hybrid write-up, but without any machine work and on a GTO mainshaft.
Old 07-07-2010, 01:09 AM
-DLS-'s Avatar
So I have to change out the actual trans internals?
Ouch, i'll pass on that.
I thought it was just maybe like a 4 inch plate that had a shaft inserted through going into a regular t56 trans to make it double ended.
Old 07-07-2010, 10:28 AM
85MikeTPI's Avatar
Ok. Shoot me a PM where this cheap C5 unit is, I'll grab it...
thanks
Old 07-07-2010, 12:01 PM
Jays_SSZ28's Avatar
thanks
Theres one sitting behind the shop next to my friends shop. This shop builds kit cars with corvette or camaro engines/transmissions. Theres stuff all over back there.
Now thats cheap to some people, not saying thats the case here.
Quick Reply: Can you convert a corvette trans into a camaro trans?
