LS1/4L80E/4x4 Swap Into 89 K5 Blazer
Ok... Here's my thoughts. I have a 1989 K5 Blazer with the 350 TBI, 700r4, and 4wd. I would like a little more power when it comes to towing and just plain performance. Going along with my thoughts that I'd like an LSx motor in anything that I can fit it, I want to do the swap into my truck (along with a few other projects I have in mind). I haven't seen this swap into a K5 and have been looking for parts to do it. So here are my thoughts. Bear with me....
LS1/LS2 Forged and Stroked
Cam/Heads
Backed by a stalled and built 4L80E
4wd functional (not sure which transfer case)
3.73 Gears in the front and rear diffs
Lifted 6" on 35" tires
and lastly for the cherry on top... Turbocharged
This truck will see towing duties sometimes whether it be a boat, or a car trailer to tow my SS. I'm wondering if anyone can offer help with any info on the swap such as mounts/crossmember a good turbo/cam/head setup.... anything that may help. Honestly not sure when I'll be able to start this swap because at the moment I'm working on opening my own shop/used car dealership. Thanks in advance for any info. Oh, and here's some pics of the Swap candidate.
Cam/Heads
It's been done in K5's. In fact I have an L59 on the stand right now waiting to go in my 83 K5. There have been a couple of writeups on other sites. There's even some kits that allow A/C without cutting the frame.
I have a 1972 GMC Jimmy 4X4 that I swapped a 2005 5.3/4L60 mated to my factory NP205 that sits in the stock location. I had to really add to the difficulty of the swap, I wanted a stock height 4X4. Moving the engine forward 2" to accomodate the longer 4L60 with the 6 bolt to 4 bolt adapter added to the clearance issues with the crossmember and front differential. I custom made my mounts/crossmember. After finally getting my last couple of bugs worked out it is a dream to drive. Quick, reliable, decent mileage.
A lifted 4X4 makes things easier.
I also believe (not sure) that an NP241 will bolt to a 4L60 and there are a couple of years with the correct drop and VSS needed for the LS PCM (but there are other VSS options). Search my name over at 1947-present Chevy GMC truck forum. I have quite a few threads and posts there.
My 89 is actually the only year of the 241 transfer case and the cable driven speedometer. I have an 03 4wd 4l60e that I'm planning on using. I'll probably have a new thread posted on it in 20 minutes or so...
http://coloradok5.com/forums/
Check out this site. There is a section on the site related to doing this type of swap. It's called The injection Section.
Scott
Scott
