18 x 10.5's Z06's... what tires will fit?
I've got 18 x 10.5's with 275/35R18's right now and they need changing. This is on a 2000 TransAm WS6 Ram Air, if that matters. How big can I get away with using these rims? I like the look of a 275/40R18 cause it fills in the wheel well a little more but can I go wider like a 295/40 or ???
Please help because I need to pick out these tires this weekend if possible. I have a couple hundred mile run I need to make and the tires I have now (F1's) are VERY dry and cracked and I don't trust em'.
10.5's all around... should've stated that... sorry... now I'm really confused. How big can I go ALL around without any issues?
Also, maybe I'm old school... I like the 35's now BUT I think I'd like a 40 for just a bit more sidewall to fill in the well...
Opinions... pics???
Opinions... pics???
Hey:
I have Nitto 555s, 285s all round 35s in the front and 40s out back with a spare pair of NT05r 315 35 18 for the rear for track use, All on 10.5 rims. Don't go any bigger than 285 for the front as that may even rub a little, 315s in the rear but may have to BFH and/or use spacers, roll lips, depending on the car. I had Nt05s all around and liked them better than the 555s.
Dub
When In Doubt Do Without
Dub
1 Post
im not tryin to steal this from the OP but what size would yall suggest for 17x9.5 all the way around cause i got 275/40/17 on it now and was just tryin to get suggestions on leave or go bigger
IMO, if your doing the same style tires, I would do a 295/35/18 rear and 275/35/18 in the front. You can also do a 315/30/18 in the rear (They will be wider, but shorter than the 295/35/18), Or if you want a drag radial, you can do a 305/35/18 in the rear (Will be a tad wider and taller than a 295/35/18). Do an advance search on those tire sizes and you will find some pictures of different tire types and how they fit on certain wheels. But Def do the 275/35/18 in front so you don't have any rubbing issues.
