Sanden Ac Compressor adapter bracket
Old 05-15-2010, 02:01 PM
aknovaman's Avatar
Default Sanden Ac Compressor adapter bracket
I found this Sanden AC compressor bracket fr $99. It adapts a generic Sanden compressor to existing LS1 F-Body engine AC brackets. I have not test fitted these to an engine but it may be a solution instead of using the variable LSx compressor in older cars.
http://www.hhclassic.com/scripts/Par...lle&KeyNo=1471
Looks same as Vintage Air bracket but uses F-body alluminum bracket too.
Seems simpler just to use the Vintage air brackets or just make these:
http://www.flickr.com/photos/46475513@N00/822264870
http://www.flickr.com/photos/46475513@N00/822265368
http://www.flickr.com/photos/46475513@N00/822264696
Found this affordable hose kit too:
http://www.nostalgicairparts.com/air...d-more-657.php
Old 05-15-2010, 03:00 PM
ls1nova71's Avatar
Linky no worky.
Old 05-15-2010, 03:27 PM
aknovaman's Avatar
Fixed link
Old 05-15-2010, 10:12 PM
S10xGN's Avatar
I used S&P brackets on mine. Expensive, but it moves the compressor inboard about 3" tighter to the motor.
Old 05-15-2010, 10:21 PM
BBPanel's Avatar
Can you explain that a little more - the 508 isn't that much smaller in diameter than the LS1 compressor is it to be able to move it inboard 3"? If one replaces all of the oem brackets is that what gives you the 3"? What about length and interference with the motor mount? Have any pics and a link to the S&P parts - I never can find anything in their catalog. Thanks. -Bob
Old 05-15-2010, 10:33 PM
S10xGN's Avatar
Bob,
Check here, then find page 91 and look at item "D". You can look through my gallery and find some engine pix that show the compressor mounted with the S&P brackets.
BTW, this is for the Corvette front drive and it runs one belt only, all on the front pulley. Because of this (I think), I had to buy a manual tensioner and ditch the auto tensioner...
Old 05-17-2010, 10:14 PM
BBPanel's Avatar
Bob,
Ok, I see now - I thought you were working in the oem location like the original post.
Old 05-17-2010, 11:14 PM
99'CajunFirehawk157's Avatar
Is the Sanden compressor known to be better than the oe ls1 compressor?
Old 05-17-2010, 11:57 PM
jeepnut24's Avatar
Do they make an adapter for the York compressors?
Old 05-18-2010, 12:52 AM
gofastwclass's Avatar
I don't believe the proper term would be "better" but possibly more compatible in certain swap situations.
Sanden has a few compressors that have become the standard in the aftermarket and hot rod circles. They also supply some (not sure how many) OEM's too. There are thousands or possibly hundreds of thousands of hot rods with their aftermarket compressors and countless OEM models on the road.
Old 05-18-2010, 11:30 AM
Ellis Juan's Avatar
That H&H bracket is exactly what I have been looking for. I wanted to mount a 508 sanden in the stock LS location since Vintage Air requires a fixed displacement Compressor. Sweet! Relatively cheap. Now to see if it actually works!!
Old 05-18-2010, 01:04 PM
AustinYukon's Avatar
EDIT: They have a Corvette one as well.
Part number 3235 if anyone needs it
Old 05-19-2010, 07:21 AM
dec010974's Avatar
Default a/c mount
another option is a kwik performance a/c adpter kit. it cost around $200. they have several kits that bring the a/c compressor upward away for the factory position. i couldn't mount my ac in the fact. position due to the motor mounts.
Attached Thumbnails Sanden Ac Compressor adapter bracket-engine-bay-002.jpg   Sanden Ac Compressor adapter bracket-engine-bay-003.jpg   Sanden Ac Compressor adapter bracket-engine-bay-009.jpg   Sanden Ac Compressor adapter bracket-engine-bay-008.jpg
Old 02-22-2011, 07:10 PM
Bowtie70SS's Avatar
Your bracket looks very nice. I would love to make a similar bracket to adapt the sanden to the CTS-V bracket that came with my engine. How were you able to hold the compressor straight while you welded it? Also did you use the 6 rib compressor?
Old 11-25-2011, 07:33 PM
Squeezer's Avatar
Anthony,
Your bracket pictures are very helpful.
Thankyou,
Old 02-09-2012, 11:40 AM
OldBBody's Avatar
For anyone looking.. I also find this one... similar to the Kwik bracket but a bit more expensive...
http://tpiparts.net/inc/sdetail/16933/19872
Old 02-09-2012, 04:23 PM
-TheBandit-'s Avatar
Wow talk about hogging something out of a big chunk of aluminum. Should hold tolerances alot better than the spacer+plate setup from Kwik, but also more expensive.
Old 02-09-2012, 04:43 PM
LSCha0s's Avatar
Wow that is beautiful.
Old 02-09-2012, 09:43 PM
chuckd71's Avatar
$350? Damn. Hope it's better than kwiks.
Old 02-10-2012, 07:19 PM
Kory 88Iroc Lt1's Avatar
Good info,
Thanks for posting the pics. Nice work
Kory
Quick Reply: Sanden Ac Compressor adapter bracket
