Throttle Body Size
Old 05-12-2010, 01:44 PM
sschevyss's Avatar
Default Throttle Body Size
Building a LQ4 and I plan to use the LS6 intake, mild cam and kit, after market injectors etc to run about 450. But I dont know jack s*** about these throttle bodies Whos is better? What size? What small mods you can make for them? Can someone help me and explain which one may benefit my application the best.
Old 05-12-2010, 02:01 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
If you are hell bent on running the LS6 intake then just port a stock LS1 throttle body and save money.
If you've got the cash then I would upgrade to a FAST. There is a FAST 90/90 combo(intake/throttle body) in the classifieds for $750
Old 05-13-2010, 12:14 AM
sschevyss's Avatar
Got ya. Just bought motor, PCM and wiring harness so the fast intake and tb will have to wait but I have considered it. You from KY?
Old 05-13-2010, 01:50 PM
Z28/2002's Avatar
I'm in SE Ohio but can be across the river in 5 minutes
Old 05-14-2010, 03:13 PM
sschevyss's Avatar
Which intake/tb setup do you run?
Old 05-14-2010, 05:26 PM
Z28/2002's Avatar
On my old '02 Z28 I had a LS6 intake with a stock throttle body
On my '02 CETA I ran the LS6 intake/ stock throttle body then went to a FAST 90/90. It now has a Victor Jr with a carb
My daily driver '00 Z28 has a LS6 intake and stock throttle body as well
Old 05-15-2010, 12:43 AM
sschevyss's Avatar
Ever tried just a stock tb but ported?
Old 05-15-2010, 07:10 AM
SweetS10V8's Avatar
With LS6 your basically stuck with a 75mm throttle body
I would find a FAST 92mm or FAST 102mm intake and use a 92mm Throttle body.
Old 05-15-2010, 02:59 PM
djfury05's Avatar
its going to be tough making 450 to the rear without heads too man.. good luck.. best bet to maximize your current setup is a FAST 90 or 92 intake and a Nick Williams throttle body to match. FWIW you can get the intake and tb for around $900-1000 depending.
Old 05-16-2010, 08:56 AM
sschevyss's Avatar
With L92 heads 450's gna b hard?
Old 05-16-2010, 09:24 AM
SweetS10V8's Avatar
huh??
this isnt a text message board, spell and use english....
Old 05-16-2010, 09:31 AM
sschevyss's Avatar
Originally Posted by SweetS10V8
huh??
I have an LQ4 I am going to use L92 heads with. Installing a good size cam, LS6 intake, full length headers, larger injectors and aftermarket fuel rails. ^^^ said its going to be hard to reach 450. I was asking, is this really going to be hard to reach my goal with that build?
Old 05-16-2010, 06:01 PM
Z28/2002's Avatar
I have a buddy that ports them but never had the time to take it off the car and let him have at it before I moved
Quick Reply: Throttle Body Size
