5.3l with 4.8l pistons
Old 05-11-2010, 06:37 PM
70TWO NOVA's Avatar
Default 5.3l with 4.8l pistons
Hey guys im building a 5.3 Lm7 and am installing flat top 4.8 pistons. Is there any need to balance the engine now since it will have new pistons?
Old 05-11-2010, 09:10 PM
bww3588's Avatar
how are you going to install 4.8 pistons? the CD is different, more than likely it will stick too far out of the hole.
Old 05-11-2010, 09:12 PM
70TWO NOVA's Avatar
it wont stick out the hole, they ar just flat tops as apposed to the dished 5.3 pistons. I just wasnt sure if it needed balancing since the piston weight would be different
Old 05-11-2010, 09:14 PM
bww3588's Avatar
.178 out of the hole to be exact.
4.8 pistons wont work.
Old 05-11-2010, 09:16 PM
bww3588's Avatar
they will stick out of the hole. the compression depth is different for the shorter stroke of the 5.3
the compression depth of the 4.8 piston is 1.498 and the compression depth of the 5.3 piston is 1.328 ish.
70TWO NOVA's Avatar
they do work, dont come out of the hole either
tdmaker (03-17-2022)
Old 05-11-2010, 09:19 PM
70TWO NOVA's Avatar
check out the build sheet on this thread...
http://www.pro-touring.com/forum/sho...ht=4.8+pistons
Old 05-11-2010, 09:23 PM
bww3588's Avatar
alrighty, i stand corrected. the rod length is different. search>me.
to address your balancing issue, i would have it balanced. but keep in mind stock engines are no where near 0 balance...i would still have it done just for peace of mind.
Old 05-11-2010, 09:25 PM
70TWO NOVA's Avatar
yeah i know the balance was not perfect from the factory, but i do know that the 5.3 pistons have a 7cc dish and that has to change the weight some from using flat tops now. Not sure if its enough to worry about though
Old 05-13-2010, 12:12 PM
ls1ya's Avatar
wow, i saw what i need to build in the garage for a couple hundo.. to a grand
Old 05-13-2010, 05:45 PM
davidws6's Avatar
Default Pistons
70 two Nova, What pistons did you go with ?
I've searched for forged 4.8 pistons = nodda ?
Old 05-13-2010, 05:46 PM
70TWO NOVA's Avatar
I bought a set from speed pro, h855cp
they arent forged though
Old 05-13-2010, 11:29 PM
vannatta20's Avatar
Try putting the 4.8 pistons on the drivers side then install the 5.3 pistons on the passenger side. This should balance well if my math is correct. Just make sure to mill the head with 5.3 pistons to even out the compression ratio.
Old 05-13-2010, 11:31 PM
bww3588's Avatar
so 4 heavier pistons and 4 lighter pistons = balanced? what kind of math you doin boy?
Gen2-LT4 (11-11-2021)
Old 05-14-2010, 12:01 AM
70TWO NOVA's Avatar
aahhh why didnt I think of that!!!??? Mitch youre a genius! lol
Old 05-14-2010, 04:55 AM
ls1ya's Avatar
i've heard it all now, what next if i use the power ball/mother's wax on my heads i'll have a port /polish
Old 05-14-2010, 08:12 AM
vannatta20's Avatar
just teasing my buddy
Old 05-15-2010, 12:55 AM
LSX92Stepside's Avatar
If anybody needs some stock 4.8 piston/rods I have a nice set of stockers from a donor motor I have. Make me an offer.
Old 05-15-2010, 07:58 AM
70TWO NOVA's Avatar
ahh now you tell me lol. I could have used those about 2 weeks ago... lol
Old 05-16-2010, 11:18 AM
hcb1700's Avatar
Just saw this thread. What a great idea. I have a stock 5.3 LM7 sitting on the engine stand and this looks like a great thing to do. Looks like I'll be doing this when I'm ready to drop the engine in my '78 Z28.
Quick Reply: 5.3l with 4.8l pistons
