AC Delco PF 46E filter?
Old 05-08-2010, 11:08 AM
blackfang's Avatar
Default AC Delco PF 46E filter?
Anyone use this? I assume it works ok.
I normally run a PF 46, but both wallyworld's in my area was out, and my work was out of them as well. I found a 46E at one of them and picked up it.
Old 05-09-2010, 08:43 AM
blackfang's Avatar
Nevermind. It was boxed wrong and had a 46 filter inside it.
Old 05-09-2010, 02:58 PM
bww3588's Avatar
whats the difference?
Old 05-09-2010, 06:45 PM
vjo90rs8's Avatar
PF61 is the truck filter, about an inch longer but holds more fluid. Its what I've used since my first old change.
Old 05-09-2010, 07:09 PM
bww3588's Avatar
i ment between the E and the non E. i figured it out now.
Old 05-10-2010, 08:12 AM
blackfang's Avatar
I wasn't using a 61 but did find out about the difference of the two I asked about.
Old 09-16-2010, 10:46 AM
Sanderd's Avatar
What is the difference between the two?
Old 10-04-2010, 11:43 PM
BumpaD_Z28's Avatar
Arrow
http://www.sandyblogs.com/techconnec...il-filter.html
~DaVe
Old 10-05-2010, 07:14 AM
HotSilverBird's Avatar
Just to let you all know those are ECORE design oil filters and are COMPLETE garbage. I had one that had a hole right through the filter media between the plastic ecore cage. BUY SOMTHING ELSE unless you like replacing expensive engine parts. Another crappy feature on the AC duracrap filters is the CUT THREADS, this leaves behind metal shavings and cutting oil. Good oil filters use ROLLED threads like Purolator and other good brands.
AC DELCO oil filters are GARBAGE!
Quick Reply: AC Delco PF 46E filter?
