GTO Engine Oil Dipstick Plug for Block- LS1 LS2
Old 05-07-2010, 03:52 PM
the-jag-guy's Avatar
Default GTO Engine Oil Dipstick Plug for Block- LS1 LS2
Does anyone know what part the GTO engines use to block off the oil dipstick hole in the LS1 or LS2 block ? I'm using a GTO pan on my conversion and need to plug the standard dipstick hole in the LS1 (Camaro) block.
Or can someone with a GTO engine Email me a pic of that area? What's plugging the hole?
Andrew
Old 05-07-2010, 04:06 PM
AJW
AJW's Avatar
Its just a mini freeze plug.
Old 05-07-2010, 04:13 PM
Default Is there a GM part number for it?
Old 05-07-2010, 05:38 PM
poconojoe's Avatar
Measure the hole and go down to the parts store and get one, why pay the dealer $10 for a part that will cost you a buck, at the parts store
Old 05-07-2010, 05:52 PM
Default Its' not that simple
This is an aluminum block that expands differently than a cast iron block that uses freeze plugs. So the rules of freeze plugs and holes sizes may not apply here. That's probably why the LS aluminum blocks don't use freeze plugs, but screw in plugs instead.
So does anyone know what the GM part number for that plug is??
Old 05-07-2010, 06:10 PM
rickykline's Avatar
have one i'll mail u
Old 05-07-2010, 06:15 PM
Default Great- thanks
Great
Old 05-07-2010, 06:56 PM
rickykline's Avatar
pm your addy and ill throw it in a envelope tomorrow youll just owe me a lol
Old 05-07-2010, 10:26 PM
poconojoe's Avatar
Lots of Aluminum motors used freeze plugs, wait until you get it and find out its a steel freeze out plug
Old 05-07-2010, 10:39 PM
rotor vs. piston's Avatar
It is, I knocked mine out to use a H3 pan. Didn't think to keep it.
Old 05-08-2010, 11:31 PM
2Aspire's Avatar
Andrew
Heres from my post in the G-body swap thread on my 05 LS2 GTO motor that I put a caddie CTS-V pan on..
One of the issues I ran in to swapping the GTO pan to the CTS-V pan was the GTO pan has the dip stick hole integrated into the pan. What I found was that there is a plug that you just need to tap out in the LS2 block with a punch to use the CTS-V oil dip stick..
Also found a thread with a closer image.. Cheers!
https://ls1tech.com/forums/generatio...installed.html
Old 11-27-2012, 06:48 PM
benz-bimmerman's Avatar
i also need one, does anyone have an extra one?
Old 08-21-2013, 04:30 PM
Dracer35's Avatar
GM part number 12557520 is for the dip stick hole plug. You can easily get it from your local dealer. or if you want to order it online i found it here.
http://www.gmpartsdirect.com/results...umber=12557520
Old 10-09-2013, 04:10 AM
MALACHI_TT's Avatar
is this the right one to use for an LQ9 dipstick hole as well?
I'm putting mine into a VY commodore which has the pan dipstick hole from factory, so using that.
thanks in advance
Old 10-09-2013, 02:58 PM
superdave84's Avatar
thanks in advance
It will fit all car and truck motors. The plug is not specific to GTO engines, it's a plug that fits the standard dipstick hole on all engines. It's only GTO-related because the GTOs are the only engine (that I know of) that plugs the dipstick hole in the block and instead uses a hole built into the GTO oil pan.
Old 10-09-2013, 08:20 PM
MALACHI_TT's Avatar
Awesome!!! Thanks mate
Quick Reply: GTO Engine Oil Dipstick Plug for Block- LS1 LS2
