what causes backfires?
Old 05-07-2010, 01:09 PM
ripgtp97's Avatar
Default what causes backfires?
LS1 trans am (a4).. first day driving it since september.
Seems to only happen sometimes if i get on it real hard.. and sometimes when im cruisin in 1st or 2nd and stomp it.. it'll backfire sometimes.. even stalled once. What could be the problem?
Old 05-07-2010, 01:15 PM
ripgtp97's Avatar
well i just read the thread about 10 posts beneath mine haha.. and its definately when i got hard on throttle then let off all the way that it backfires.. is it normal for it to completely stall sometimes though?
Old 05-07-2010, 03:36 PM
01ssreda4's Avatar
No, stalling is not part of a car's running condition. If the car is basically stock then I would look for obvious things like plugs, wires, fuel/air filters, and 02 sensors. All are good items to put on your spring tune up list. Also consider cleaning your MAF.
Old 05-20-2010, 08:09 PM
ripgtp97's Avatar
well i cleaned the maf, and have plugs and wires on the way.. I did a top engine clean with mopar combustion chamber cleaner, and it'll only stall now sometimes if i go WOT.. i'm really hoping its just plugs, and maybe some filters.. but what else could be problems? Running too rich, not really sure what to think (my rear O2's are tuned out as well)
Old 05-20-2010, 08:12 PM
ZigZagZ's Avatar
Is it backfiring thru the exhaust, or thru the intake manifold?
Exhaust = Rich
Intake = Lean
Old 05-20-2010, 08:33 PM
ripgtp97's Avatar
not sure how you can tell the difference? but i hear it popping out the exhaust, and when it stalls i don't really hear a backfire, just dies out
Old 05-21-2010, 10:49 AM
TooLateVTEC's Avatar
The plugs are probably killed from the CC cleaner you used.
A fouled plug will cause a backfire through the exhaust.
Old 05-22-2010, 02:58 PM
ripgtp97's Avatar
well im changing the plugs.. but it was stalling even before i did the chamber clean
Old 05-22-2010, 05:08 PM
stngtamr29's Avatar
Exhaust leak everytime
Old 05-22-2010, 05:10 PM
stngtamr29's Avatar
Sounds like two problems one being the exhaust leak.
Old 05-22-2010, 05:30 PM
ripgtp97's Avatar
exhaust leak and what else? im not worried about the exhaust leak sinc eim getting headers in about a month
Old 05-22-2010, 05:59 PM
stngtamr29's Avatar
Does your check engine light come on? Mine did this awile back and it was the Mass air but alot of times when mass airs act up it will turn your line pressure up in your tranny and it will shift hard. Mine jurked so hard going into gear that it broke 4 teeth off the pinion gear in my old 10 bolt.
Old 05-22-2010, 06:19 PM
ripgtp97's Avatar
my tranny does shift kinda hard actually compared to other cars i've driven, but there's no SES light on.. i had the rear O2's tuned out..anyway to check this mass air?
Old 05-23-2010, 04:50 AM
lovescamaros28's Avatar
bad plugs or wires,running too rich,or exhaust leak. a backfire is caused when unburned fuel(hydrocarbons)combust in the exhaust.
Old 05-24-2010, 11:28 PM
torqls1's Avatar
id like to know this aswell how to check mass air cuz when i shift it jerks the car everytime pretty noticeable
Old 05-25-2010, 06:46 PM
ripgtp97's Avatar
Today i went 3/4 throttle everything was fine.. as soon as i gave it that little more and at about 5k RPm.. either when it shifted or just hit 5k, it stalled.. definately a differnet smell from the exhuast when it does this as well
Quick Reply: what causes backfires?
