does the ecm store odometer readings
Old 01-09-2004, 02:08 AM
atiparts's Avatar
Default does the ecm store odometer readings
I was just wondering if the ECM or any other electronic box other than the gauge cluster stored the mileage of the car .
Old 01-09-2004, 07:41 AM
Ozz
Ozz's Avatar
No, I belive that is stored in the BCM (body control module) or something like that, now I could be speaking out of place but thats how I understand it.
Old 01-09-2004, 07:58 AM
Red01Chevy's Avatar
Im not sure about the F-body's but i kno for sure that in the trucks it is stored in the cluster.
Old 01-09-2004, 04:06 PM
SDB
SDB's Avatar
Hmmm...seems like someone has a loose dash and it needs tightening...it can still be done.
Old 01-09-2004, 09:13 PM
wrencher
wrencher's Avatar
The only piece that keeps the total milage is the IPC=instrument panel cluster.
Old 01-09-2004, 10:09 PM
onehardmaro's Avatar
Yup i have a 100k mile car with a 15000 mile gauge cluster.
Old 01-09-2004, 11:08 PM
66ImpalaLT1's Avatar
Cluster on the corvette also
Old 01-09-2004, 11:48 PM
Jammer's Avatar
Not sure what to say but....if thats the case full disclosure upon all sales in NOW necessary.
Old 01-12-2004, 04:41 PM
1fastWS6's Avatar
I know for sure that the cluster contains the mileage. I'm 99% sure that the PCM and/or BCM also contains the mileage. You can pull the mileage using a GM Tech2. But that doesn't mean that you can't swap the PCM and/or the cluster and have conflicting mileage records.
Craig
Quick Reply: does the ecm store odometer readings
