lq4,small cam and all bolt ons 400whp?
Old 04-23-2010, 10:19 PM
Kory 88Iroc Lt1's Avatar
Default lq4,small cam and all bolt ons 400whp?
I have an 05 lq4 that I will be installing with a t56 and 8.8 ford rear with either 355 or 373 gears, in my 94 s10 shortbox. I plan on using 1 3/4" lt headers and dual exhaust, an ls6 intake, cia, underdrive pulley and a small custom cam, (probably by Pat G) could a setup like this make 400whp with good driveability and decent mileage? Or should I look at an L92 head and L76 intake top end?
Any info would be appreciated.
Thanks,
Kory
Old 04-24-2010, 06:48 AM
SweetS10V8's Avatar
Ive got an LQ9, Lingenfelter CNC L92 heads, 1 3/4" LT, FAST 102mm intake, cai, underdrive pulley, small Comp cam (219/235 .607/.621 113+5) in my S-10.
It made I think 407whp, found out later the fuel pump was giving up and going from 58psi to 35psi.. I still havent changed the pump yet
Heads are going to be what make or break your power. Buy the best ones you can afford(see sig), There are very good cathedral and L92 head avaliable
Old 04-24-2010, 10:40 AM
I know what you mean about heads, on my camaro I bought Advanced Induction heads and couldn't be happier. I will probably go with the L92 top end. I just wanted to see if I could get where I wanted to be with the stock 317 heads. The truck will be my daily driver, and not see the track much.
Thanks for the input. Are you on s10 forum?
Thanks,
Kory
Old 04-24-2010, 10:58 AM
SweetS10V8's Avatar
Im a moderator there.
Old 04-30-2010, 06:52 PM
Does anyone have an opinion about making 400whp with the stock 317 heads and a small driveable cam? I'm trying to decide if spending the money on an l92 top end is required to meet my goals. Any input would be appreciated.
Thanks,
kory
Old 04-30-2010, 08:07 PM
SweetS10V8's Avatar
Why do you have to have 400rwhp?
Old 04-30-2010, 08:39 PM
outkast6991's Avatar
a 222/224 565/565 in my lq4 just made 375hp/385tq. this is with tsp stage 1's and regular bolt ons. not really what i was hoping for but it drives very well
Old 04-30-2010, 08:57 PM
I figure that it will take around 400whp to trap 117. I don't absolutely have to have it. If I could make say 380whp with the 317 heads and a small custom cam I would probably be fine with that.
Kory
Old 04-30-2010, 09:36 PM
Justus67's Avatar
Mill the 317 heads .020-.030 to bump your compression, TSP 228R and supporting mods (valves, springs and rods) and you should be right at 400 or more with a good tune and that m6.
Old 05-01-2010, 10:56 AM
3pedals's Avatar
freind of mine has stock 03 LQ4,cam only - comp 228/230 cam, vic jr/carb, 1 3/4" headers. engine made 478hp on engine dyno(not wheel hp).
I agree w/justus67 - mill the stock 317's .030" and cam similar to 228/230, and your there. my.02
Old 05-01-2010, 11:34 AM
SweetS10V8's Avatar
Ive done and LQ4 with L92 heads, Comp 219/227 cam, headers, FAST intake and it made 485-500fwhp.
Old 05-01-2010, 12:19 PM
King Nothing's Avatar
i'm going to be running stage 2 243 heads (West Coast Racing Cylinder) on my LQ4 408 go with a good company for a good head and you'll be happy. mine is being built for boost so my cam is a 226/232
Quick Reply: lq4,small cam and all bolt ons 400whp?
