Stock LS1 Rods
Old 04-14-2010, 08:16 PM
T_Jizzle92's Avatar
Default Stock LS1 Rods
I was wondering how strong a set of stock LS1 connecting rods with ARP bolts would be. I've rad the rods were pretty strong from factry but I've never seenan exact amount of horsepower hey could handle. I'm rebuiding an LS1 and was wondering whethe or not to buy new rods
Old 04-14-2010, 08:21 PM
02*C5's Avatar
The weak point in the LS motor I think is 99 and older is the rod bolts so if you upgrade the rod bolts you are all in. My buddy was pushing 620 rwhp and 690 rwtq on a stock bottom end ls1 T76 single on an e85 conversion.
Old 04-14-2010, 08:33 PM
RARON455's Avatar
I have heard around the 500 range. Heard more and less, I wouldnt recommend just putting rod bolts in it, some people have had luck with it and some have had terrible results. A ton of threads on this debate.
Old 04-14-2010, 08:37 PM
T_Jizzle92's Avatar
well the engines from an 00 camaro and im estimating the engine to bea round 500 hp when its all said and done, i was just wonderin if i should invest in a new set of rods or not.
Old 04-17-2010, 10:24 PM
brooknasty's Avatar
stockrods are supposed to be good to 500HP. the weak spot is the factory bolts. get the ARP bolts and problem solved.
Old 04-17-2010, 10:42 PM
ls1ya's Avatar
As with everyone else 500 hp and the rod bolts are the weak point
Quick Reply: Stock LS1 Rods
