dbw not working help please
Old 04-03-2010, 10:37 AM
lrazer's Avatar
Default dbw not working help please
I have a 01 5.3 and 03 pedal and tac module. The motor will fire up and idle fine without the module and pedal hooked up, but with them hooked up it wont start the fuel pump relay clicks rapidly when you turn the key on. also the scanner wont communicate. with the module unhooked i was able to get these codes
[PCM] P1120 - Throttle Position (TP) Sensor 1 Circuit (SES) (History) (Immature)
[PCM] P1220 - Throttle Position (TP) Sensor 2 Circuit (SES) (History) (Immature)
[PCM] P1221 - Fuel Pump Secondary Circuit Low (SES) (History) (Immature)
[PCM] P1275 - Accelerator Pedal Position (APP) Sensor 1 Circuit (History) (Immature)
[PCM] P1280 - Accelerator Pedal Position (APP) Sensor 2 Circuit (History) (Immature)
[PCM] P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance (SES) (History) (Immature)
[PCM] P1518 - Electronic Throttle Module to PCM Communication (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P1571 - Traction Control Torque Request Circuit (Old) (History) (Current) (Immature)
Old 04-04-2010, 08:03 AM
Old Geezer's Avatar
What yr is the PCM??
Old 04-04-2010, 12:34 PM
lrazer's Avatar
The pcm, harness, throttlebody, and engine are all 01. The pedal and tac module are 03.
I read this on another board:
Originally Posted by Bo185
Make sure they are the correct pedal and TAC box for the application. That might be part of the problem.
TAC module has two connections, one for the pedal harness..other hooks into main engine harness this is all you need it should have the 9-pin connector the later ones are 6-pin.
TAC modules have to match up to the year range of the PCM AND the throttle body.
03-05 TAC module works with 03-05 truck TB and 03-05 PCM (BLUE/GREEN connectors)
01-02 TAC module works with 01-02 truck TB, 97-04 Vette TB, and 01-02 PCM (BLUE/RED connectors).
03-05 TAC modules have an aluminum mounting base, 01-02 TAC modules are all black plastic including the mounting base.
So this seems to be my problem, is this correct?
Old 04-04-2010, 05:20 PM
poconojoe's Avatar
Go here
http://www.chevythunder.com/
Leonard has a good explanation of DBW parts and interchanges with pictures to help you identify the parts
Old 04-05-2010, 12:19 PM
lrazer's Avatar
seems like i need an 03 throttle body but the 01 pcm supposidly should work
Old 04-05-2010, 07:39 PM
pdsq98gt's Avatar
That 01 truck pcm most likely won't be able to control the tac. Is the harness pinned for dbw?
Old 04-05-2010, 08:42 PM
poconojoe's Avatar
If it has a DBW OS in it, it will since in 2001 and 2002 they used the same 12200411 PCM for both DBC and DBW applications
Old 04-06-2010, 11:35 PM
lrazer's Avatar
the motor was dbw
Old 04-06-2010, 11:39 PM
lrazer's Avatar
so i got the throttle body that goes with the tac but its the 8 pin single connector, i assume i need to get the connector and just wire the 2 and 6 wire connectors to it?
Old 04-07-2010, 05:09 AM
poconojoe's Avatar
You can make it work but IIRC you need to switch 2 of the wires. By the way 2001 didn't use the single plug throttlebody
Old 04-07-2010, 08:58 AM
Formerly 99-2door-08/30/2010
PitchblackC3's Avatar
You can NOT run a 2003 throttle body and TAC on a 2001 PCM.
Trust me, I tried it.
When I got my C3 the stock 2001 DBW throttle body was damaged and it was impossible to find a 2001 DBW throttle body. (now of course they are all over ebay, and cheap!). I put a 2003 Throttle body and TAC in my truck and ran it that way for a while. Everything worked great unless you pressed the pedal to 80% or more. It would immediately trigger reduced power mode (engine running or not), and the ignition would have to be turned off for about 2 minutes to reset it. The 2001 PCM and 2003 TAC are incompatible, they will not communicate correctly.
I solved the problem by repinning my harness and running a 2003 PCM as well. Works great, but I do get BCM codes when I put on my scanner. Also I never got the PCM to correctly activate the AC clutch. I figured I would wire it straight to the switch if summer came and I hadn't figured it out, but now I am going a different route.
Today I am switching everything back over to 2001 PCM, TAC and pinning the harness back the way it was. I am putting on a TBSS intake and 90mm throttle body which will work with the 2001 TAC without an adapter module.
Side note, my 2001 accel pedal works successfully with both 2001 and 2003 TAC/PCM.
Old 04-07-2010, 10:24 AM
lrazer's Avatar
would that be something that could be tuned out. this is in a less than stock application...
Old 04-07-2010, 10:27 AM
lrazer's Avatar
so my 03 pedal may work with 01 tac
maybe i just need to find someone who wants to trade tac's
Old 04-07-2010, 08:19 PM
There is nothing you can do with the tune. The problem lies in the difference in serial protocol between the 2 years.
The AC problem could perhaps be fixed with the tune, but as of now the software doesn't have that option.
Old 04-08-2010, 01:13 AM
lrazer's Avatar
im not running ac anyway so thats not an issue its just this dbw stuff holding me up
Old 04-25-2010, 10:00 PM
LS88FoxBody's Avatar
https://ls1tech.com/forums/conversio...lp-please.html
https://ls1tech.com/forums/12915568-post134.html
Old 01-06-2012, 04:44 PM
5.3fj60's Avatar
I am having the same problem. Did you find a solution?
Old 01-30-2013, 07:19 AM
Jcarlisle's Avatar
Anybody find the answer to this
Old 01-30-2013, 08:55 AM
LS1Tech Sponsor
BP Automotive's Avatar
as stated above, the second generation drive by wire(03-07ish) will not work with the first generaton DBW PCMs. That was his issue.
It is always best to try and get all of the parts from the same vehicle if possible. However, the pedals are all interchangeable.
Most generally, all of the 03-07 stuff should work together. I have seen times when it did not. Its really a crapshoot unless you get them all from the same year. (ideal if not from same vehicle.)
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 01-30-2013, 08:05 PM
Jcarlisle's Avatar
Default Dbw
My motor, pedal and module all came from same vehicle to my knowledge. I do know for sure that my motor,ecu came from 2002 tahoe. Salvage yard sent me later on a DBW module and pedal. My module is all plastic and my pedal is all metal except APP SENSOR is obviously plastic. With TAC MODULE connected engine will not start, data port(aldl) goes out and fuel pump relay clicks rapidly. At this point I have verified that TAC module is getting 12v , all wires are correct and not broken or melted together. APP sensor is functioning properly in their suggested ranges. If I apply pedal down nothing happens at the throttle body. If TAC module is unplugged then engine cranks, runs and then idles up because TAC MODULE is unplugged. Any suggestions would be greatly appreciated. Sorry for hi jacking someone else's thread but I am hoping someone can help and if someone else read this maybe it will save them the trouble that I have been dealing with. Thanks
Quick Reply: dbw not working help please
