Which wiring harness for a Ls Swap?
Old 04-01-2010, 08:30 PM
mred's Avatar
Question Which wiring harness for a Ls Swap?
no matter what car or truck that your putting it in.
which harness or who's harness do you suggest?
who's got the better deal?
thanks
Ed
Old 04-01-2010, 08:54 PM
mred's Avatar
oh i dont have a harness and im really not patient enough to build one from scratch.
might have someone that could help build one,i just dont have a harness currently.
was looking at this guys harness.
http://www.larryselectricsite.com/LS1.html
Old 04-01-2010, 09:08 PM
ls1nova71's Avatar
If you're going to mod your own harness, F body harnesses are the easiest and cleanest. Alot less wires than a truck harness.
Old 04-01-2010, 09:59 PM
Mike52's Avatar
If you absolutely have to buy a 'built' harness, you can't go wrong with a Speartech harness, give John a call, tell him what you're working on. He is always here offering assistance.
Mike
Old 04-01-2010, 11:27 PM
the_merv's Avatar
I built mine out of a F-body Harness..
Old 04-02-2010, 01:29 AM
ge_forcez22's Avatar
I'm building mine out of a truck harness... lots of wire to get rid of.
Old 04-02-2010, 05:29 AM
bjamick's Avatar
I'm using a truck harness with the fuse box also. It wasn't bad at all to pull the wires not needed out. I got rid of a bunch of wires out of my harness.
Old 04-02-2010, 05:56 AM
Petraszewsky's Avatar
I got my harness from Current Performance Wiring....
Old 04-02-2010, 06:13 AM
Klimaxx's Avatar
got mine from techrods...very happy with it..
Old 04-02-2010, 07:21 AM
Pocket's Avatar
Built my own, and several others
Old 04-02-2010, 02:03 PM
you have any pictures of your harness?
-Garrett
Old 04-02-2010, 03:57 PM
NemeSS's Avatar
u not going carb no more?
Old 04-02-2010, 06:50 PM
welldonecj7's Avatar
If you were to use a corvette one with a DBW is it tough to convert to standard cable driven TB? Any disadvantages to Corvette harness?
Old 04-02-2010, 07:04 PM
mred's Avatar
possible different project,s-10
Old 04-02-2010, 09:06 PM
LSX-Yota's Avatar
I have heard alot of good things about techrods harness...
Old 04-02-2010, 10:08 PM
AJW
AJW's Avatar
I personally have not used one of Larry's harnesses, but I have been to his shop a couple of times. He was very helpful and knowledgeable and was willing to talk as long as I wanted without the guarantee of a sale. Not sure if that helps you out or not??
AJW
Old 04-03-2010, 06:23 AM
Jones'n's Avatar
I melted down a bunch of pennies and made my own wire, stranded and twisted it by straining it through a calendar, then coated it with high temp insulation I made from composite plastics I had laying around, colored the wires as needed with food die, and then used all of that to build my own harness.
Assembled my own engine computer with old parts I had from Broken Pacman Machines, and an Apple IIe.
It's not that tough, just takes time, you guys should try it.
Old 04-03-2010, 11:33 AM
mred's Avatar
LOL!! wise guy...
plug in connectors,fuse block,relays,nothing to start with at all.
which direction would you go?
even if you didnt have a Pacman machine,or Atari
Old 04-03-2010, 11:45 AM
flynbrian48's Avatar
I'm cheap, am modifying my own from the truck harness with the 6.0. In the past, I've used harness' in their entirety using ALL the donor componants, including VATS, not knowing how to do it nor where to start. It doesn't seem that hard now that I've jumped into doing my own. I say that, before I've gotten it together and the engine running...
Old 04-03-2010, 12:53 PM
NemeSS's Avatar
y u dont post on carbedlsx no more?
i got some pics of my parts on there now and more comin
Quick Reply: Which wiring harness for a Ls Swap?
