Timing twister?
Old 03-29-2010, 08:51 PM
billymz28's Avatar
Default Timing twister?
I am looking for a way to retard my timing for my nitrous. I have been looking at the timing twister and from my understanding it plugs into the crank and cam sensor and keyed 12v and ground. My question is can you get to the cam sensor without pulling the intake. And the crank sensor without pulling the starter. It is on a 99 vette. Just looking for the quickest and easiest way to pull my timing my bottle is full and I wanting to spray it bad just need to retard the timing.
Old 03-30-2010, 08:56 AM
rambodog's Avatar
Do you mean the timing tuner? If so you just need to plug it into the crank sensor which is above and very close to the back end of the starter. You will need to get the starting motor out of the way to reach it. You will need to drop the exhaust manifold to get to the starter. The 2 nitrous wires need a 12v source and a ground. I don't know about the timing twister. If you have the timing tuner are you going to also utilize its window switch function?
Here is a link to a pic of the crank sensor plug on a C5
http://forums.corvetteforum.com/c5-t...o-starter.html
go to post #8 and open that link for the picture
Old 03-30-2010, 04:52 PM
billymz28's Avatar
sorry I meant the timing twister. And I have headers is that going to free up some room
Old 03-30-2010, 05:32 PM
Chris@NitroDaves
Guest
Posts: n/a
If you are looking for the easiest / best way to pull timing then i'd suggest going with the lingenfelter unit http://www.nitrousoutlet.com/catalog...1&product=3467 . It plugs into the coil packs and is easy all getout to wire up.
Old 03-30-2010, 06:04 PM
billymz28's Avatar
Ok so far looks good can this be used as a window switch also.
Old 03-30-2010, 07:54 PM
billymz28's Avatar
Originally Posted by mchdg86
Yeah I second this one Billy. It looks stupid easy to install and plus you get a 2-step also. I'll probly eventually get that also.
Yeah Craig I think I am going to order it and just get a bolt on tune from Glen this weekend. You better get your setup done or your going down. You need to take sat off and cruise up to okc with me road trip. Thought about hitting the street scene up there.
Old 03-30-2010, 08:11 PM
mchdg86's Avatar
Haha if I had the money for a tune I would go in a heartbeat. But I don't unfortunitly. I don't know about you taking me but it would probly be a close one. Oh wait you forget you're on street tires and I'm on ET street radials so you will defanitly have your work cut out for you lol.
Old 03-30-2010, 08:16 PM
billymz28's Avatar
I aint worried with your 2.0 reaction time on street. And besides Ill just call you out when your drunk again. Man what gear am I supposed to shift to.
Old 03-30-2010, 08:25 PM
rambodog's Avatar
Its not a window switch and yes the heafers will be in the way in order to reach the starter
Old 03-30-2010, 08:34 PM
mchdg86's Avatar
You will have to wait a while to call me out when I'm drunk because I haven't been drinking as much lately.
Old 03-31-2010, 03:43 PM
Chris@NitroDaves
Guest
Posts: n/a
The lingenfelter is just a timing controller / 2step only.
Old 03-31-2010, 05:29 PM
billymz28's Avatar
yeah I finally found a little more info on it. I went ahead and ordered it. I guess I will do a window later.
Quick Reply: Timing twister?
