When I run the AC water(not coolant) leaks onto the floorboard 2001 camaro
Old 03-15-2010, 11:58 AM
soundengineer's Avatar
Default When I run the AC water(not coolant) leaks onto the floorboard 2001 camaro
I have a 2001 camaro
when I run the AC I get water leaking onto the floor on the passenger side
not sure why..
Need suggestions and advice on how to fix this
including a basic description of what I'm going to have to take apart to get at the problem to fix it..
Old 03-15-2010, 12:01 PM
RARON455's Avatar
Normally there is a drain tube in the climate box that dumps under the car, sounds like yours might be plugged or something.
Old 03-15-2010, 12:10 PM
DomesticDisturbance's Avatar
im willing to bet the drain is clogged. find it and clean it out and you should be good.
Old 03-15-2010, 12:32 PM
can anybody tell me exactly where this drain is so that I dont take apart half the car trying to get to it...
Old 03-15-2010, 01:11 PM
the_merv's Avatar
It's on the bottom of the AC Box under the Hood. Clean out that area..sounds like some crap got in there.
Old 03-15-2010, 01:18 PM
like I can probably get to it from under the car? or do I get to it from the top?
passenger side? towards firewall?
Old 03-15-2010, 01:58 PM
yea passenger side towards firewall but im not sure what the best way to get to it is.
Old 03-15-2010, 02:17 PM
shaun's Avatar
dirt and bugs can get up there and clog it up.
i had a mustang where those little tiny beatles made a nest in that tube and it was leaking on the floor board.
got a hanger and cleared it out.
Old 03-15-2010, 02:57 PM
biggb1783's Avatar
I use compressed air and my long blow gun to open them up. If not available to you a clothes hanger works fine.
g/l.
Old 03-15-2010, 03:07 PM
2001NBMZ28's Avatar
Here's what it looks like on a '95, ours is similar:
http://shbox.com/1/a_c_drain.jpg
Old 03-15-2010, 04:37 PM
thanks.... exactly the thing I needed...
I got under the car...looked in that general area...found the drain...reached up there with a coat hangar....got it it all cleaned out....
a **** ton of crud and water came out...LOL
now we'll see if I got it clean enough to solve my leak
Quick Reply: When I run the AC water(not coolant) leaks onto the floorboard 2001 camaro
