Oil pressure dropping under high RPM / load ?
Old 03-08-2010, 09:32 PM
Self-Admitted Scammer
ls2pontiac's Avatar
Default Oil pressure dropping under high RPM / load ?
I noticed once i get over 4,000 RPM and you are foot the floor in 2nd gear, the oil pressure goes down to 25lbs and jumps up to 40 in about 2 seconds. What could be the cause of this? I have a canton pan, and my builder told me to run 7 qts. could the gauge be wrong? It really makes me sick seeing that, especially how i just spent 10k on a new motor..
Old 03-09-2010, 01:27 AM
Wicked94Z's Avatar
windage man, i have the same problem. try running it with 5-6 quarts and see if it improves...
Old 03-09-2010, 01:40 AM
gregrob's Avatar
You should also run a high flow filter....
The K&N 3002HP is what I run. It filters excellent and is very high flow.
Old 03-09-2010, 03:07 AM
firehawk238's Avatar
i have this same problem but since my oil pressure never goes low enough to not lubricate the engine, ive not been extremely concerned with it. i have a canton road race pan with a built in windage tray though. so would it still be doing this?
Old 03-09-2010, 04:20 AM
speed_demon24's Avatar
I had the same problem with my canton pan. I ended up having to taking out the built in windage tray/screen and putting a moroso windage tray off the main caps to fix it.
Old 03-09-2010, 05:27 AM
FASTFATBOY's Avatar
My first 355 did that, cam bearings were going south. Telltale sign of that is an oil leak on the water pump shaft.
Old 03-09-2010, 05:35 AM
mklinger's Avatar
I have seen oil pressure vary due to a failing o-ring where the pick up tube hits the block. Just a thought
Old 03-09-2010, 06:18 AM
FASTFATBOY's Avatar
Old 03-09-2010, 06:46 AM
well seeing as how my pickup fell off and thats why i changed the pan/pump, i honestly cant recall if i had this problem with the stock pan. i didnt realize the canton pans had this problem. will definately look into this further. glad i read this thread.
Old 03-09-2010, 06:51 AM
shbox's Avatar
And where would this alleged o-ring be?
Old 03-09-2010, 06:53 AM
shbox's Avatar
You don't indicate what pump you are using. Aside from windage, it could be cavitation.
Old 03-09-2010, 07:13 AM
FASTFATBOY's Avatar
#2 Where does the pickup bolt TO THE BLOCK?????????????
Old 03-09-2010, 10:13 AM
RamAir95TA's Avatar
LOL that's awesome!
Old 03-09-2010, 10:14 AM
ls2pontiac's Avatar
Melling 10554 with standard spring. I put 6 quarts in this time...hmm. Do you think anything got hurt by it dropping to 30 lbs at almost 6000 rpm real quick a couple of times? It always bounced back within a second or 2.
Old 03-09-2010, 11:42 AM
since it only truly takes 8psi of oil pressure to lubricate the small block chevy, id say you should be ok.
Old 03-09-2010, 12:25 PM
Matts94Z28's Avatar
My car does the same thing, even after it was rebuilt. It always seems to drop right at the 4000rpm mark and shoot back up. I think it is due to windage to be honest. At first I thought it might have been the bearings, but it continued after I replaced everything. It hasn't hurt me yet.
Old 03-27-2010, 10:15 AM
wrd1972's Avatar
Mine does this too. I got a Melling 10554 w/ white spring and the gauge bhavior looks like an inverse bell curve.
Someone define windage please.
Old 03-27-2010, 10:33 AM
ls2pontiac's Avatar
with 6 quarts in it, no problem now. i knew 7 qts was going to be a problem
Old 03-27-2010, 01:34 PM
97Z28SS's Avatar
Could also be the oil climbing the rear of the pan, I installed a $10 Moroso rear pan baffle just for this reason.
Old 03-27-2010, 08:48 PM
wrd1972's Avatar
I think my 4K drop is g-force induced.
2K-4K = 50#
4.1K-5.5K = 35#
5.6K -6.5K = 50#
Most stupid question ever cause maybe I am not capable of reading my dipstick.
This is what my dipstick markings looks like.
ADD●xx●xx●xx●◄──OPERATING RANGE●
The level on my dipstick is here, should it be further to the right:
_____________/\
Example A
Is this condidered absolute full:
_______________________________/\
Example B
____________/\
Dont rip me to bad guys.
Quick Reply: Oil pressure dropping under high RPM / load ?
