Unpinning connectors? GT - Weatherpack?
Old 02-20-2010, 08:51 PM
Lurk's Avatar
Default Unpinning connectors? GT - Weatherpack?
I've got a GMPP harness with a DBW pedal. I need to unpin the wires and remove the connector so I can pass the harness through the firewall. Problem is I've tried using a pushpin or a paperclip and they don't come loose. It's making me feel stupid hahaha
Anyone have a hint on how to temporarily remove the wires from the plug housing on a DBW harness? I believe this is referred to as a GT connector?
I've pulled a lot of electrical connectors apart in the past, but this one is making me cautious.
Old 02-20-2010, 09:09 PM
S10xGN's Avatar
Not sure what the wiring "spec" is on that connector. I have a Weatherpak tool and a Metripak tool. The WP tool looks like a ballpoint refill and slips over the pin, compressing the tang. The MP tool is a bit harder to use. It's pointed like an awl, but ground flat on one side. You stick it into the shell, wiggle it around while saying your choice of "prayer"...
Old 02-20-2010, 09:39 PM
Lurk's Avatar
hahaha oh schit.
Here's what I'm working with.
Attached Thumbnails Unpinning connectors? GT - Weatherpack?-photo.jpg   Unpinning connectors? GT - Weatherpack?-photo2.jpg
Old 02-20-2010, 11:05 PM
gofastwclass's Avatar
You need tool #2 (metripack).
Caspers Electronics PN 108108
Old 02-21-2010, 06:02 AM
Jones'n's Avatar
You don't need any special tool.
Just pop the purple secondary lock off the back side, and the purple cover off of the face (remove them completely) Then you will see the little plastic tabs that hold each terminal in. Just use a paperclip or small jewelers screwdriver to lift up on the plastic tab, and the terminals will slide out the back of the connector.
Old 02-21-2010, 08:23 AM
poconojoe's Avatar
I have no problem getting the front cover off the female connector, but is there a trick to getting it off the male sideof the connector?
gofastwclass I have that tool it doesn't fit in the holes on the front cover of those connectors, Jones'n way works the best, but I sometimes use that tool to lift the tab, after the front cover is off
Old 02-21-2010, 08:31 AM
True, but I found this and it's two brothers in a set for $20, which I couldn't pass up since it had the other tool (yellow handle) for the PCM connectors with it.
I've used the method you described and got a bit heavy handed and damaged the terminal which creates more work than using the right tool.
Old 02-22-2010, 01:14 PM
Lurk's Avatar
holy carp, the face pops off too? I gotta try this.
Old 02-22-2010, 09:34 PM
Gary U's Avatar
It really is that easy. Did the same thing about 2 weeks ago to feed my harness through the existing speedo cable hole in my Chevelle. I used a very fine point dentists pick to lift each of the tabs after first removing the purple plastic piece.
Old 02-22-2010, 11:42 PM
Lurk's Avatar
damnit, it really is that easy. I just did it. I have some dental tools too! I used the heavy angled scraper to get under the lip of the cover and it gentally popped loose. After that it was a simple to get between the crimp and retainer then pry.
Old 02-23-2010, 08:56 AM
Lurk's Avatar
I appreciate all the replies. Thanks Gary and Jones!
Old 01-04-2021, 02:20 PM
oldeerslayer's Avatar
I realize I'm reviving an ancient thread here, but need to know what those tiny connectors are named so I can order some for my harness.
Been looking on line for hours with no luck. Trying to repin an 04 C101.
Old 01-04-2021, 04:15 PM
79LS1FOX's Avatar
I think they're Aptiv(used to be Delphi) GT150 terminals, I get mine from Mouser.
Old 01-04-2021, 04:56 PM
Thanks, How can I tell 150's from 280's, which is what I thought they looked like?
Old 01-04-2021, 05:58 PM
TrendSetter's Avatar
the 150s are smaller. they usually go by center spacing between pins so i think 150s are 1.50mm and 280s are 2.80mm
Old 01-07-2021, 04:03 PM
Project GatTagO's Avatar
Received 1,390 Likes on 878 Posts
The numbers refer to the male terminal blade width. 150 is 1.5mm, 280 is 2.8mm, 480 is 4.8mm, etc...
Andrew
Old 01-07-2021, 05:00 PM
andrews right.
Old 01-15-2021, 12:53 PM
Good stuff here:
Andrew
oldeerslayer (01-15-2021)
Old 01-15-2021, 02:31 PM
Thanks, the video really shows how to remove and install the pins correctly.
Quick Reply: Unpinning connectors? GT - Weatherpack?
