Ford 9 inch C5 Disc brakes???
Old 02-16-2010, 08:55 PM
Blownz28man's Avatar
Default Ford 9 inch C5 Disc brakes???
Does anyone offer a conversion kit to adapt c5 brakes to the 9"? Its a big bearing new end style. Or maybe even the LS1 brakes? Any info would help!
Old 02-17-2010, 06:39 PM
ttt... No one?? What is the common rear brake setup?
Old 02-17-2010, 11:13 PM
SS SLP2's Avatar
I do not know anything about the C5 setup, I and most ppl use LS1 stock backing plates and stock rotor, calpier/pads
Johnny
ps:just found this
http://www.umiperformance.com/catalo...t99m1c2vdsmtg5
Old 02-19-2010, 01:36 PM
monzaman44's Avatar
Default C5 Brakes for 9 inch rear end
Just bought everything for my 9 inch. Google KORE 3. Then call and ask for Tobin. He should square you up.
monzaman44
Old 02-20-2010, 11:21 PM
Ok thanks guys. I just would like to keep c5 brakes all around. i know the C5 rears have the drum parking brake type setup. I may have to adapt the to the Big ford old housing ends.
Old 02-22-2010, 07:23 PM
Good call on Kore 3. They have what i needed. Thanks!
Old 02-24-2010, 08:50 PM
Ok.. What is the real advantage of weld on/ bolt on brackets. I would really like to retain my parking brake even though I dont really need it. Its an auto. looking at the GM metric calipers with jeep rotors. You use a weld on bracket
Old 02-25-2010, 06:52 PM
well hell. C5s it is. I dont need a parking brake
Quick Reply: Ford 9 inch C5 Disc brakes???
