Drag Racing Tech
Project removable "one piece" front end using factory bumper and fenders
Old 02-08-2010, 06:51 AM
Fireball's Avatar
Default Project removable "one piece" front end using factory bumper and fenders
Was inspired by the 275 buildup thread in this section so I decided to take a crack at making a "one piece" front end using OEM parts and pinon hood. I just started on it this past weekend while snowed in during the blizzard of 2010
Using a VFN 5" sloped pin-on hood (extended to the windshield)
As a starting point, I used a VFN fiberglass front end mounting kit (comes with the necessary brackets and tabs...easier than building from scratch)
here it is mocked up on the ground:
Note the clecos...they are holding the front attachment plates. Here is a picture from the back side. The bar that goes across the bumper is what holds the front in place (this is the bar held in with clecos in the previous picture)...this bar locks it in place both up/down and side to side. The small bar in the back is just for mockup...keeps the back of the fenders at the proper distance.
These are the plates that the front bar interlock with
Now its time to cut a sh%t ton of metal out of the front My plan is to use some chromemoly to make supports for the fenders (and for the hood dzus tabs) and to use some small tubing to make supports for the OEM headlight covers
Old 02-08-2010, 08:16 AM
5.3LJimmy's Avatar
Looks good so far. This is probably the kind of thing I would be doing if I was snowed in. Good luck with it.
Old 02-08-2010, 09:50 AM
nickp's Avatar
Looks cool! That thing will be easy to work on when you can pull whole nose off.
Old 02-08-2010, 11:10 AM
Cliff's Avatar
Can't wait to see what the finished product looks like.
Old 02-08-2010, 11:30 AM
Rickys S/C Z28's Avatar
that is bad ***
Old 02-08-2010, 04:33 PM
InsaneAuto86's Avatar
Originally Posted by Rickys S/C Z28
that is bad ***
+1... tht looks awesome!
Taubr Unit's Avatar
Old 02-08-2010, 04:40 PM
tals7's Avatar
that looks good.have you seen the gold ohio boy ta he has same thing but did it alot differet(smaller tubes)his was light also.
Old 02-08-2010, 05:59 PM
LSmonster's Avatar
Subscribing. And please keep the pics coming.
Old 02-08-2010, 06:48 PM
tektrans's Avatar
Good stuff fireball, keep them coming.
Old 02-09-2010, 05:48 AM
Fireball's Avatar
I had to use 1 1/4" tubing since my fuel cell is going up front (needs a saftey cage around it)
Old 02-09-2010, 06:12 AM
LS1Tech Sponsor
MADMAN's Avatar
I would add a couple 1/2" bars to the front support.
__________________
www.madmanandcoracing.com
225-343-9029
Old 02-09-2010, 07:17 AM
Fireball's Avatar
I am. this is just the start. I have plates and 1/2" tubing to support the top and bottom of the bumper. I'll probably work on that next.
Old 02-09-2010, 08:29 AM
Race your car!
JL ws-6's Avatar
Couple round bar pieces to a flat tab that runs alotn the bottom, trim the "flap" that used to go up to the stock bumper support, and it should be nice and solid.
Pretty cool trick, making the whole nose come off as one piece like that. I assume, that you can get away with that for classes that say "no one piece front ends", because it's made from the stock body panels correct?
Old 02-09-2010, 09:54 AM
Fireball's Avatar
its not a one-piece front end...its simply factory stuff mounted a bit different...
Old 02-09-2010, 09:59 AM
Race your car!
JL ws-6's Avatar
Right Damn near the closest thing you can get though
Old 02-09-2010, 10:16 AM
ulakovic22's Avatar
Looking forward to your progress and finished product. VERY cool idea, but what is the advantage to making it removable? On a tube chassis I can see access to everything, but on a stock type chassis won't it still be enclosed by the strut towers? Are you only looking for a ton of room up front for turbos, piping, fuel cell, etc.?
Old 02-09-2010, 10:21 AM
Fireball's Avatar
more room and reduced weight
Old 02-09-2010, 11:18 AM
trigger1's Avatar
Interesting idea.
Old 02-09-2010, 12:13 PM
Reject's Avatar
I'll admit I'm interested!!
Quick Reply: Project removable "one piece" front end using factory bumper and fenders
