anyone try out the GM flip key ?
Old 01-27-2010, 08:20 PM
chrysler kid's Avatar
Default anyone try out the GM flip key ?
nevermind, even if you got the keyless entry to work the ignition key is the wrong pattern
they make them for vettes but it doesnt look like the ignition key is the same either. vettes use the same wireless remote, this vette one actually has you put the factory guts into the new remote
Old 01-27-2010, 08:31 PM
munecorey's Avatar
I've been wanting to this for a long time, where can i get it?
Old 01-27-2010, 08:36 PM
02CamaroSSLE's Avatar
i HATE flip keys...
Old 01-27-2010, 08:38 PM
its on ebay, search for "chevy flip key". however like i said im not sure if it would work, it looks like it should tho once you get the key cut and disable the VATS system
they are like $40
on second thought im not sure if the key dimensions are the same.
Old 01-27-2010, 09:01 PM
Old 01-27-2010, 09:06 PM
Trans Am Jam's Avatar
i want one!
Old 01-27-2010, 09:43 PM
98NBM1's Avatar
seems cool, wonder how it would work with an aftermarket alarm
Old 01-27-2010, 10:55 PM
Camaro Chris's Avatar
I want one also! why did i not think of this!
Old 01-28-2010, 12:09 AM
evilZO6's Avatar
How would this work with Keyless Entry? You program the new remote or something?
Old 01-28-2010, 12:42 AM
Douchebag On The Tree
justin455's Avatar
Yes, you can buy any GM keyfob technically and have the dealer reprogram it and it will work just fine.
At first I was going to say it won't work because the first pic is Pass Key III, but the vette pics posted are for the Pass Key II system that F-bodies have, so in get one of those remotes and it will work once reprogrammed.
Old 01-28-2010, 06:40 AM
TireSm0ke's Avatar
Its actually really easy to reprogram the key fob. Pull the radio fuse, turn the key to the on position and back 3 times and hold down the lock and unlock buttons on the remote.
Blksilvr (11-01-2020)
Old 01-28-2010, 10:22 AM
with the vette one i posted they come empty, so you actually put the guts of your factory key FOB into them. i was excited about the vette one at first because they are made for the c5, which uses the same remote, but it looks like the key patter itself wouldnt support cutting an acceptable fbody key
yeah that one looks like its a full remote, if not you could just swap the guts, but im still pretty sure the blade is the wrong key pattern. you would need to see if they could cut either that malibu key i posted in the first post into an fbody key, or if that vette key could be cut to the right dimenstions
Old 01-28-2010, 10:27 AM
dragonZ28's Avatar
2010 Camaro has switchblade keys.
Old 01-28-2010, 10:49 AM
'Trust''s Avatar
Hmm, my Viper keyfob is identical to the ones that were on the T/A, I wonder if they program the same? That'd be sweet.
Old 01-28-2010, 12:47 PM
therobman's Avatar
corvettekey.com has them i just emailed them asking if i could get one blank with out the corvette crap on it if so im ordering one
Old 01-28-2010, 01:31 PM
i would ask if the key part itself would work in an fbody. the corvette key is a bit different, its double sided where as the fbody has a flat side. i would email them and ask if there is any way to get the key part to work with an fbody
Old 01-28-2010, 03:45 PM
I wants one!!!
Old 01-28-2010, 06:01 PM
The Dragon's Avatar
Bump for more info
Old 01-28-2010, 08:00 PM
think47's Avatar
this seems cool
Old 01-28-2010, 08:11 PM
raptorws6's Avatar
It would be nice to have one.
Quick Reply: anyone try out the GM flip key ?
