LS1/LS6 Interference or NON interference?
Old 01-24-2010, 10:12 PM
LouisvilleZ06's Avatar
Default LS1/LS6 Interference or NON interference?
I thought this would be an easily googled/forum searched question...but I can't find a solid answer.
so are LS1/LS6 Motors Interference (as in timing chain breaks and valves get bent) or non interference (as in timing chain breaks and its no biggie)????!???
Old 01-24-2010, 10:33 PM
BarneyMobile's Avatar
They're interference fit. If your timing chain breaks, you'd better pray that only the push rods bend.
Old 01-24-2010, 10:48 PM
NAVY99B4C's Avatar
they will get f'd up.
Old 01-25-2010, 06:31 PM
Hector's Avatar
Not a problem. Our timing chains don't break.
Old 05-02-2013, 12:43 AM
supergenius's Avatar
Yes. They do.
Old 05-02-2013, 12:52 AM
Super Hulk Smash
JakeFusion's Avatar
I went overkill with a Rollmaster double. If it breaks, the whole engine is doomed anyway.
ATI Harmonic Balancer also helps - most of the time timing chains break due to bad harmonics.
And yes, interference.
Old 05-02-2013, 05:41 PM
96capricemgr's Avatar
why are you asking?
You have some "timing belt is maintenance" idea? If so you are wrong.
Quick Reply: LS1/LS6 Interference or NON interference?
