Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
2010 4.10 & 3.73 Richmond Gear Sets Available @ TSP!!
Old 01-12-2010, 02:08 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default 2010 4.10 & 3.73 Richmond Gear Sets Available @ TSP!!
Guys we have several sets of the Richmond 4.10 & 3.73 gear sets arriving for you guys looking to add a little bit more gear to your 2010 cars!
http://www.texas-speed.com/shop/cate...MID=11&catid=6
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-12-2010, 10:45 PM
acowherd's Avatar
How would the ls3 handle 4.10 on the street?
Old 01-13-2010, 06:59 AM
jamnut's Avatar
It would easily handle them, better so if you have an M6 car with stock 20's.
Old 01-13-2010, 11:54 AM
Formula51's Avatar
A 4.10 is a great all around gear for a manual 2010 Camaro SS. It would be a must have if I owned one.
Theoretical speeds with 4.10's on an M6 assuming a 28.7" tire and 6600rpm redline would be as follows:
1st = 45
2nd = 66
3rd = 96
4th = 137
5th = 163
6th = 241
3.73's would be a waste as you would have to just barely shift to 4th before the traps. Plus, the highway difference between 3.73 and 4.10 isn' that much given the 0.57:1 6th gear ratio.
Old 01-13-2010, 11:25 PM
treedoc2000's Avatar
What about 410 for the autos??
Old 01-14-2010, 09:15 AM
Formula51's Avatar
I have never looked at the auto's, but apparently that is why they offer 3.73's!!!!
3.73's look to be an excellent gear for the auto's. Here's the speed breakdown:
1st = 34
2nd = 58
3rd = 89
4th = 119
5th = 161
6th = 204
First and second gear are really low in the auto and I can see some stalled Camaro's running sick times with gears and tires. Those launches will certainly tell us how strong the rear is.
Old 12-05-2010, 01:14 PM
Martin718's Avatar
I have a 2011 SS M6 and was considering a 4.10, would that be a good gear with a pro charger in the process??
Quick Reply: 2010 4.10 & 3.73 Richmond Gear Sets Available @ TSP!!
