New L96 RPO...
Old 01-05-2010, 02:17 AM
hefftone's Avatar
Location: Dallas, Ga (2.7 miles from Southeastern Dragway)
Default New L96 RPO...
http://archives.media.gm.com/us/powe...10truck_us.htm
For 2010, GM is showing a new RPO "L96".... 6.0L, 9.6:1 CR, iron block kind of as a garden variety 364.... I know the LY6 has L92 rectangle port heads, but so far, I have'nt found out if this L96 is using them, or the LQ4/9 cathedrals. I'd hate to pass up a gem in the junkyard. Anybody???
Old 01-05-2010, 11:22 AM
J-Rod's Avatar
2010 Vortec 6.0L V-8 VVT ( L96 ) 6/5/2009
Description: 6.0L Gen IV V-8 Small Block
Type: V-8
Displacement: 5967cc (364 ci)
Engine Orientation Longitudinal
Compression ratio: 9.6:1
Valve configuration: Overhead valves
Valves per cylinder 2
Assembly site: Romulus, MI
St. Catharines, On
Silao, MX
Valve lifters: Hydraulic roller
Firing order: 1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x stroke: 101.6 x 92 mm
Bore Center (mm) 111.76
Fuel system: Sequential fuel injection
Fuel type: Applications:
Regular unleaded Chevrolet Silverado HD, Chevrolet Suburban, GMC Sierra HD, GMC Yukon XL
Regular unleaded Chevrolet Express ( Cutaway ), GMC Savana ( Cutaway )
E85 Flex Fuel Chevrolet Express ( Passenger,Cargo ), GMC Savana ( Passenger,Cargo )
Engine Mass TBD
Applications: Horsepower: hp ( kW )
Chevrolet Silverado HD < 10,000 lbs 360 hp ( 268 kW ) @ 5400 rpm SAE CERTIFIED
GMC Sierra HD < 10,000 lbs 360 hp ( 268 kW ) @ 5400 rpm SAE CERTIFIED
Chevrolet Silverado HD > 10,000 lbs 322 hp ( 240 kW ) @ 4400 rpm SAE CERTIFIED
GMC Sierra HD > 10,000 lbs 322 hp ( 240 kW ) @ 4400 rpm SAE CERTIFIED
Chevrolet Suburban HD 352 hp ( 262 kW ) @ 5400 rpm SAE CERTIFIED
GMC Yukon XL 352 hp ( 262 kW ) @ 5400 rpm SAE CERTIFIED
Chevrolet Express 323 hp ( 241 kW ) @ 4600 rpm SAE CERTIFIED
GMC Savana 323 hp ( 241 kW ) @ 4600 rpm SAE CERTIFIED
Applications: Torque: lb-ft ( Nm )
Chevrolet Silverado HD < 10,000 lbs 380 lb-ft ( 515 Nm ) @ 4200 rpm SAE CERTIFIED
GMC Sierra HD < 10,000 lbs 380 lb-ft ( 515 Nm ) @ 4200 rpm SAE CERTIFIED
Chevrolet Silverado HD > 10,000 lbs 380 lb-ft ( 515 Nm ) @ 4200 rpm SAE CERTIFIED
GMC Sierra HD > 10,000 lbs 380 lb-ft ( 515 Nm ) @ 4200 rpm SAE CERTIFIED
Chevrolet Suburban HD 382 lb-ft ( 518 Nm ) @ 4200 rpm SAE CERTIFIED
GMC Yukon XL 382 lb-ft ( 518 Nm ) @ 4200 rpm SAE CERTIFIED
Chevrolet Express 373 lb-ft ( 506 Nm ) @ 4400 rpm SAE CERTIFIED
GMC Savana 373 lb-ft ( 506 Nm ) @ 4400 rpm SAE CERTIFIED
Maximum Engine Speed: Silverado, Sierra, Suburban, Yukon XL = 6000 rpm Express, Savana = 5600 rpm
Emissions controls: Catalytic converter
Three-way catalyst
Positive crankcase ventilation
MATERIALS
Block: Cast iron
Cylinder head: Cast aluminum
Intake manifold: Composite
Exhaust manifold: Cast nodular iron
Main bearing caps: Powder metal
Crankshaft: Cast nodular iron with undercut and rolled fillets
Camshaft: Hollow steel
Connecting rods: Powder metal
Additional features: Electronic throttle control
E85 Flex Fuel
Extended life accessory drive belt
Extended life coolant
Extended life spark plugs
Oil Life Monitor System
Variable valve timing ( VVT )
Old 01-05-2010, 11:24 AM
J-Rod's Avatar
I would suspect with the HP ratings that it is a cathedral port head. But, I have not been able to find a definitive answer on the GM site.
Old 01-05-2010, 01:15 PM
camarols1's Avatar
The L96 uses the same part number cyl head as the LS3, so it has rectangle ports.
Old 01-05-2010, 01:54 PM
J-Rod's Avatar
ok, so it is a VVT 6.0L with an iron block with L92 heads.
So, yes, it would be a good find for someone looking to do a 6.0L with L92 heads...
Old 01-05-2010, 05:14 PM
hefftone's Avatar
Hmmm, the L96 and LY6 have the same Peak torque @ the same RPM. The Horsepower is very similar as well, could that be just a slightly different cam?
Would you mind telling me what resource you used to determine this? It would be very helpful for me in the future.
Old 01-05-2010, 08:17 PM
camarols1's Avatar
myself,
Old 08-19-2010, 10:38 PM
LS1MonteSS's Avatar
Well I just scored a L96 and 6L90E Complete with only 2 miles on the motor..
Once I get a chance to look at it close I"ll try to post some part numbers...
Old 08-20-2010, 10:19 AM
-TheBandit-'s Avatar
Did you get that from Schaums? I thought about buying that motor.
I'm pretty sure the L96 is the Flex Fuel version of the LY6.
Old 08-20-2010, 09:20 PM
Custm2500's #1 Fan
silver-mod-o's Avatar
My L76 motor is an aluminum block 6L with L92 heads from an 07 Vortec-Max otioned truck. I wonder (besides block material) what the differences are
Old 08-20-2010, 09:44 PM
Irish350's Avatar
2 miles? the hell happened to that truck?
This is interesting, seems like a budget build dream, especially for boost..
Old 08-20-2010, 11:27 PM
The L76 in the pickups has VVT like the LY6 and L96, but unlike the LY6 & L96 it also has AFM (active fuel management) aka DOD (displacement on demand).
Old 08-22-2010, 08:21 AM
bhop42's Avatar
The l96's will replace the ly6's. The only difference between the two is that the l96's are e85 ready.
Old 08-23-2010, 09:39 PM
LS1MonteSS's Avatar
Yeah I got it from Schaums.. I made an offer, he mad a counter offer, I made another offer 1/2 the difference and the next morning I got an email that they accepted it.. I'm so stoked... I talked to the guy there to get some background.. I said really only 2 miles on that motor.. He said yeah, it was damaged in transport on the back half of the van..
I have been searching for all the info I can get for upgrades and I guess it is still that new.. I hope this goes a long way to putting my 70 Monte Carlo into the 20th century..
Old 08-23-2010, 10:06 PM
LS1MonteSS's Avatar
It was damaged in transport from the plant.. I asked the guy.. Ok how is it that the motor only has 2 miles on it.. he said the back of the van got tore up and they scraped the whole thing... I am NEVER this lucky like this.. I just hope I can pull some ponies out of it with usual bolt on items
I was thinking an LS3 Intake, cam and headers... I'm stuck on the headers.. I am thinking the mid length headers not long or shorties.. Not sure how the length plays into things..
Old 08-23-2010, 10:37 PM
SweetS10V8's Avatar
Thats what Schram's and Norstram's do, they are official GM dismantlers. They always tear apart new vehicle that got damaged somehow before making it to the dealerships.
I bought a 5 mile engine from Nordstrams and the pistons were still shinny, you couldnt even barely tell the engine had ever been run!
Old 08-23-2010, 10:41 PM
Quick99TransAm's Avatar
Default Schaum's
Dumb Question but was is Schaum's
Old 08-23-2010, 11:23 PM
Irish350's Avatar
Id go longtubes or keep the manifolds. Unless what youre putting it in comes with tri ys a lot and you can change the flange. The manifold they come with is good, and length makes all the difference.
Old 08-24-2010, 07:44 AM
SweetS10V8's Avatar
http://stores.ebay.com/Schram-Auto-Parts
Old 08-24-2010, 09:57 AM
Congrats! Do you mind sharing what you paid for it? I went back and forth with them a few rounds on price early in the auction, but they wouldn't budge at the time. That thing was super clean. What are you putting it in?
Quick Reply: New L96 RPO...
