50/50 mix or straight antifreeze
Old 12-21-2009, 12:12 PM
BlackBirdRyder02's Avatar
Default 50/50 mix or straight antifreeze
sum nut told my freind to use straight antifreeze instead of a 50/50 mix in his car is he right? because he said the water part of the anitfreeze with evaporate
Old 12-21-2009, 12:15 PM
eseibel67's Avatar
Your friend better not take advice from that bonehead.
Best protection is 50/50 mix.
Old 12-21-2009, 12:38 PM
sscamaroburn02's Avatar
i've always been told dexcool 50/50
Old 12-21-2009, 01:12 PM
Mr Incredible's Avatar
From an article I found...
"More antifreeze is not always better. Antifreeze's key ingredient is glycol, and it works best at a 50 to 70 percent mixture with water. For example, coolant made up of half antifreeze and half water will have a freeze point of -34 degrees F. Pure antifreeze freezes at about 12 degrees F.
We recommend going only as high as 70 percent Zerex and 30 percent water to drive the freeze point down," says Dave Turcotte, technical director of Valvoline's Zerex coolant brand. "Once you exceed 70 percent coolant, the freeze point actually starts going back up.
Turcotte recommends keeping a gallon or two of coolant, premixed with deionized water, in each machine. When it is used to top off radiators, the proper concentration is preserved."
Old 12-21-2009, 01:44 PM
i though so
Old 12-21-2009, 01:53 PM
3.8redbird's Avatar
pure antifreeze will make the car run hotter as well. doesnt disperse heat as well as water
Old 12-21-2009, 03:09 PM
LS6427's Avatar
If you live in a climate that doesn't get to freezing temps....all you need is 1 jug of Dexcool in there, the rest water. I use a half jug of Dexcool here in South Florida.
If you do live in a climate that see's freezing temps.....50/50 is good, but even a little bit less then 50/50 is ok. 40% Dexcool, 60% water. It won't freeze.
DO NOT use 100% Dexcool or any other kind of anti-freeze.
Old 12-22-2009, 08:45 AM
Save the manuals!
wssix99's Avatar
Whatever you do - don't let your friend drive your car.
Old 12-22-2009, 10:40 AM
Squirts11's Avatar
sum nut told my friend...
Exactly.
Old 12-22-2009, 10:55 AM
pjb
pjb's Avatar
plain water cools better then antifreeze, but does not have any of the freeze protection, lubricants or other beneficial additives. By "plain water", I mean distilled water that has harmful minerals removed to reduce build ups.
All antifreeze is not only NOT better, it is actually much worse.
Quick Reply: 50/50 mix or straight antifreeze
