Recall for GXP
Old 12-20-2009, 12:27 PM
steveman0018's Avatar
Default Recall for GXP
MY stepdad has an 06 GXP and he just recieved a recall letter stating about the power steering cooling line might leak and it could damage the pump. You would notice it by spots on the ground from fluid.
Now i have an 07 impala and i havent recieved a letter. I know they got the same engines, hs anyone else recieved this letter, GXP, monte, impala? and what year
i know this has beena known problem for this car but if there a recall for all of them i rather get it fixed now then to have it break later.
Old 12-20-2009, 12:43 PM
06 SS's Avatar
it is only for certain cold weather areas. Chicago does not qualify, although mine blew spectacularly some years back.
Old 12-20-2009, 12:54 PM
i live in the same area.. it just confuses me..
Old 12-20-2009, 02:44 PM
neilownz's Avatar
Ongoing recall. The hose can get brittle and freeze/break in the cold. Should be able to tell if it's been replaced by the gm warranty work record. But you can drive without power steering so I don't see the big deal.
Old 12-20-2009, 02:49 PM
06 SS's Avatar
If you lose your hose, you can burn up the PS pump itself, and that is a big deal.
Old 12-20-2009, 03:57 PM
nmp0098's Avatar
Does anyone know if this applies to 07s too? Or is it particular to 06s? I lost a power steering line driving a car home from the auction and drove it 20 more miles home without fluid in the pump, and even though it was still drivable until the car died (once I replaced the line) the steering required more effort and the power steering pump whined waay louder than the supercharger (series 1 3800).
Old 12-20-2009, 04:08 PM
06 SS's Avatar
mine whined for about a week after and then settled down, no problems in the 50Kish miles since then. I think mine was more of a bleeding issue than actual pump damage. The recall was started after the 07's were manufactured, so I am sure you have the same hose.
Old 12-21-2009, 10:11 AM
SidewaysV8's Avatar
http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
Old 12-23-2009, 12:01 AM
speedshifter's Avatar
I work for a Chicago dealer and we were notified that its not a recall, just a "Special Policy." Meaning no action is needed unless yours fails, then its covered.
On a GXP (or any LS4) you replace the complete return line which has an actual cooler made into the line where the stock one does not.
Old 12-23-2009, 08:03 AM
07SSport's Avatar
I was told that this recall is for 06 Impalas (and apparently GPs) only, not 07's and up. And yes it is for cold weather areas only as well. However, the PS in my 07 feels pretty crap-tastic.
Old 12-23-2009, 10:22 AM
stealthls4's Avatar
I live 30 miles north of milwaukee and have a 2006 GXP and got the letter. I too work at a GM dealer and had it done. Had no problems with mine with 62K now but figured I would do it if it was free! haha
Old 12-24-2009, 11:05 AM
Its a customer satisfaction campaign, not a traditional recall. Heres what it says:
#09132: Customer Satisfaction - Power Steering Hose Leak - (Nov 23, 2009)
Subject: 09132 - Power Steering Hose Leak
Models: 2006 Chevrolet Impala, Monte Carlo (V6 & V8 Engine)
2005-2006 Pontiac Grand Prix (V8 Engine)
Due to part availability, this bulletin is being administered in phases. You will be notified as phases are released.
*****THIS PROGRAM IS IN EFFECT UNTIL FEBRUARY 28, 2011.*****
Condition
Certain 2006 model Chevrolet Impala and Monte Carlo vehicles equipped with a V6 or V8 engine, and 2005 and 2006 model year Pontiac Grand Prix vehicles equipped with a V8 engine may have a condition in which the power steering cooler line may leak or split. When these vehicles are started in cold weather, the pressure on the hose is substantially higher than in warmer weather and may exceed the strength of the power steering hose or clamps. If this were to occur, the driver would likely notice fluid spotting under the vehicle when the vehicle is parked and a decrease in the power steering assist. If enough fluid were lost, damage to the power steering pump could occur.
Correction
Dealers are to replace the power steering hose assembly on vehicles with a V8 engine, or replace a length of hose and clamps on vehicles with a V6 engine.
Vehicles Involved
Involved are certain 2006 model Chevrolet Impala and Monte Carlo vehicles equipped with a V6 or V8 engine, and 2005 and 2006 model year Pontiac Grand Prix vehicles equipped with a V8 engine, and built within these VIN breakpoints:
Year
Division
Model
From
Through
2006
Chevrolet
Impala
69100003
69438808
2006
Chevrolet
Monte Carlo
69100406
69438794
2005
Pontiac
Grand Prix
51230922
51356980
2006
Pontiac
Grand Prix
61100004
61315421
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using GMVIS (dealers/retailers using WINS) or Investigate Vehicle History (dealers/retailers using GWM). Not all vehicles within the above breakpoints may be involved.
I just did mine a week before this campaign came out. When you do it on an LS4 car you need to detach every engine/trans mount (besides the upper dog bone) and raise the engine 3 inches. You then remove the rear cradle bolts and lower the rear of the cradle 2-3 inches and that gives you enough room to get the line out. Funny thing was that I found my front engine mount was completely busted in half doing this job, would have not have found this otherwise.
Old 01-30-2010, 12:02 AM
imnmbr1's Avatar
Mine just broke wooo hooo up here in MN. There it sits in my driveway with no fluid. Hopefully since i bought it 6 weeks ago I just havent gotten the letter
Old 02-04-2010, 06:09 AM
Wicked_C5's Avatar
hmnnn interesting
Quick Reply: Recall for GXP
