New Optispark and still doesnt start.
Old 11-18-2009, 10:24 AM
brians91formula's Avatar
Default New Optispark and still doesnt start.
My Grandfather needs some help with his LT1. It is a 1940 Ford with a 96 LT1 motor out of a Corvette. He let the car sit in one of those portable garages last winter and the car has not started since. I think condensation killed the Optispark so we bought a new Optispark and waterpump. It still will not start. It just turns over and doesn't fire. Any other ideas ? Maybe the ignition control Module ?
Old 11-18-2009, 10:25 AM
djjab57's Avatar
ICM would be my first guess, should of tried that and the coil first
Old 11-18-2009, 11:22 AM
Just put a brand new ICM on and coil. Still wont start. Could it be something to do with the computer ?
Old 11-18-2009, 11:26 AM
djjab57's Avatar
have you checked the fuel pressure
Old 11-18-2009, 11:44 AM
I have not personally, grandfather might have. I will make sure I check that tonight. thanks.
Old 11-18-2009, 11:58 AM
SS#502's Avatar
Double check all your grounds, the ICM is really sensitive to not having a good ground.
Old 11-18-2009, 01:01 PM
fergymoto's Avatar
If you follow this diagnostic you will figure out the problem
http://www.mainstreamtopics.com/foru...p?showtopic=78
Old 11-18-2009, 01:04 PM
awesome ! I will use that as well.
Quick Reply: New Optispark and still doesnt start.
