99 camaro ss window adjustment
Old 10-23-2009, 04:11 PM
bambaboy's Avatar
Default 99 camaro ss window adjustment
I have a friend that just bought this car, and I can't get the window to seal against the weatherstip correctly, I've been studying the shbox.com website for a while now and even looked at it while adjusting the window and still can't get it right. Any ideas? could the regulator be worn?
Old 10-23-2009, 06:43 PM
davered00ss's Avatar
Check general repair & maintenance.
Old 10-24-2009, 10:13 AM
Save the manuals!
wssix99's Avatar
Where is it not sealing and how wide is the gap?
Old 10-24-2009, 11:33 AM
bambaboy's Avatar
the rear top and rear bottom of the window (towards rear of the car) you can almost stick your finder through the gap at the rear bottom, we already replaced the weather strip
Old 10-25-2009, 09:02 AM
Save the manuals!
wssix99's Avatar
This isn't an adjustment issue, then. Something is probably busted.
Pop off the door panel and see if you have one of the two issues in these threads:
https://ls1tech.com/forums/general-m...-included.html
https://ls1tech.com/forums/general-m...w-related.html
Old 10-25-2009, 05:42 PM
bambaboy's Avatar
I think he might have the same issue as the second link, here are some pictures I took, (crappy iphone camera) any suggestions?
Quick Reply: 99 camaro ss window adjustment
