Need stock gear ratio for 93-97 m6s
Old 10-22-2009, 12:25 PM
95ls1formula's Avatar
Default Need stock gear ratio for 93-97 m6s
Well here is the problem, i just bought a 95 trans am m6 with a couple of mods. After buying it i figured out the pervious owner replaced the rear end becuase he f*cked the stock one up and now it only had 2.73's in the rear and i was wondering what the stock gear ratios are for trans ams. i thought trans am gear were bigger stock. Can somebody please help.
Old 10-22-2009, 01:13 PM
itSSlowZ28's Avatar
all 6spds were 3.42's to my knowledge
Old 10-22-2009, 04:50 PM
Spartan7's Avatar
Except 93's.
Old 10-22-2009, 07:26 PM
What should my speed be at like 75 in 6th or 65 in 6th?
Old 10-22-2009, 07:45 PM
LS1W66's Avatar
Approx 16-1800 in 6th with stock 3.42's @75mph
Also keep in mind the stock Tach's are off by roughly 200 rpm
Old 10-22-2009, 10:07 PM
massls1guy's Avatar
Nice calculator here, see the 'specific trans ratio' one:
http://www.jawsgear.com/calc_rpm.html
75mph with 3.42's in 6th gear: 1679RPM
65mph with 3.42's in 6th gear: 1455RPM
75mph with 2.73's in 6th gear: 1340RPM
65mph with 2.73's in 6th gear: 1161RPM
Old 10-22-2009, 10:24 PM
Camaro 6speed gear ratio is the same as firebirds im guessing. Because the rear end is out of a 96 camaro and i drove it today, its a 16xxrpm at 75 so im guessing it has 3.42s then. also the tires are 225/55r16s
Quick Reply: Need stock gear ratio for 93-97 m6s
