OBDII Scanner can't connect(Resolved)
Old 10-13-2009, 12:23 PM
rusnrno's Avatar
Default OBDII Scanner can't connect(Resolved)
I have tried 4 or 5 different scanners and they all have the same message. "Error communicating with vehicle".
I have checked the following on the ALDL port,
pins 4 and 5 for ground, pin 16 for 12 volts with key on and I verified continuity from the blue PCM harness pin 7 to ALDL pin 2.
The car runs and drives fine but the SES light is on and it's running rich.
Old 10-13-2009, 02:26 PM
BlackZJ's Avatar
I may be wrong. But as far as I know, the pre 98' F-Bodies are OBD I. They may have an OBD II Plug but are ODB I.
-Mat
Old 10-13-2009, 04:30 PM
rusnrno's Avatar
-Mat
1996 was the first year for OBDII.
Old 10-13-2009, 05:51 PM
koolaid_kid's Avatar
Have you connected to it before using an OBDII scanner?
96 & 97 LT1s can be converted to OBDI and still use the OBDII connector, just like the 95 LT1s, which came from the factory as OBDI with an OBDII connector.
Old 10-13-2009, 06:24 PM
rusnrno's Avatar
Yes I have scanned it many times.
This problem started after I installed the engine out of a 95 Firehawk. I used my PCM and harness. The 95 doesn't have a Crankshaft position sensor so that would be a DTC. I installed my EVAP solenoid, coil and a new 96 Knock sensor. My rear O2s have been disabled in a previous tune by Madtuner.
Old 10-14-2009, 06:50 PM
rusnrno's Avatar
TTT
Any ideas?
Old 10-18-2009, 02:40 AM
cccullins's Avatar
Thumbs down
I had same problem and was pulling hair when guy to me to check cig lighter cause obdII shares same fuse and sure nuff fuse was bad replaced it and problem solve, hope this helps.
Old 10-18-2009, 03:06 AM
swaggard's Avatar
check your fuses
Old 12-02-2009, 05:56 AM
wajouba's Avatar
anyone got the 100$
wajouba's Avatar
lol sorry wrong thread HAHAHAHA
Old 12-02-2009, 10:01 AM
rusnrno's Avatar
Problem solved!
Put this one in the "Dumbest things I've done" thread.
Here's what happened. During the time I was swapping engines, I ended up with 3 PCMs. One was my original(OBD2), one was out of the 95 Firehawk(OBD1) that I parted out and a 3rd one. I had marked each of them, but, somehow I switched the 96 with the 95 and installed it in my car.
I discovered this when trying out the other PCMs to see if the one in the car was fried. The car ran better and I checked the service numbers and Voilla!
All the pieces of the puzzle fell together after that. The high idle, running rich, the ALDL port not working, etc.
Quick Reply: OBDII Scanner can't connect(Resolved)
