How much more does mild steel weigh than stainless?
Old 08-03-2009, 04:56 PM
98Camarod's Avatar
Default How much more does mild steel weigh than stainless?
That's all I really want to know is how much more mild steel weighs than stainless steel. I don't have a tig and a mig is much cheaper
Old 08-03-2009, 06:51 PM
edcmat-l1's Avatar
Mild steel doesn't weigh more than stainless.
Old 08-03-2009, 06:52 PM
98Camarod's Avatar
Wow, I thought there was a weight difference. Thanks for the reply Ed
Old 08-03-2009, 08:52 PM
TransAm11973's Avatar
as longs as its the same thickness, you wont see a big difference in weight. Also you can use a mig to weld stainless steel, you dont have to have a tig. Tig is nicer because you wont get splatter and its a bit easier to control your pool. With mig you will get splatter and controlling your pool is a bit more tricky because it just doesnt flow well. As long as you get spatter block and use it well, you will be fine. I weld stainless at work all the time and use a mig if i have to, no problems just make sure you are using 308 stainless wire
Old 08-04-2009, 10:03 AM
xfactor_pitbulls's Avatar
Stainless is around 5 or 6% heavier than mild steel. I forget the exact number. Mig welding stainless is a process alot of production companies use. But I wouldnt recommend it for someone that doesnt have knowledge of how to setup your machine. You can make a much worse mess than running Er-70 wire.
Old 08-21-2009, 10:37 PM
95maroz28's Avatar
not to jack but if repairing a set of stainless steel headers would it be better/easier to use mild steel tubing or stainless steel tubing and a mig? i have to replace the u bend on the bottom side of an slp header and was wondering what j bend the get.
Old 08-30-2009, 03:05 PM
Jimbo1367's Avatar
Use Flux core SS wire (Mig) and eliminate the splater.
Old 09-19-2009, 05:40 PM
SJM Manufacturing Inc's Avatar
Calculate the total volume or area you're using of material and use density to calculate weight. Depending on what grade material you're using, the density will vary slightly. Generally speaking mild steel is ~7.85 g/cm^3, 304 is ~8 g/cm^3.
The weight should come out to about 1.875% difference if you calculated it.
Old 01-19-2019, 09:01 PM
ajaxbolt's Avatar
AISI 440C has 16 to 18% chromium and 0.95 to 1.2% carbon. Steels are generally 66% heavier than aluminum but specific strength, the ratio of strength to density, is the property of interest for aircraft designers. ... AISI 304 stainless steel has the lowest strength-to-weight ratio of the five. Iron with a steel content of about 1.5% is high-carbon steel. Its density is approximately 7,840 kg/m^3, only slightly less dense than soft steel, but denser than cast iron.
Old 01-20-2019, 12:17 PM
jlcustomz's Avatar
Keep it stainless, keep it tig welded.
EDIT, wow, just noticed the original post dates.
Quick Reply: How much more does mild steel weigh than stainless?
