How Do you test the coil packs ?
Old 07-30-2009, 05:05 PM
WS6.17's Avatar
Default How Do you test the coil packs ?
My check engine light came on, so I scanned it and said that it had more then one misfire?
Old 07-30-2009, 08:51 PM
lakefx7's Avatar
ls1 coil packs are pretty much indestructable. i work at a gm dealership and have yet to see them fail. what codes do you have? p0300? any other codes? you likely have another issue spark/fuel related. no one can help without codes you pulled from it. give us a starting point.
Old 07-30-2009, 11:47 PM
WS6.17's Avatar
I got it scanned and it said multipile mis fire p0300. It has stock injectors the check engine light stays on and some times will flash while driving, when i hit the accelertaor black smoke will come out?!
Old 07-31-2009, 12:47 AM
Formerly darynC-10/23/10
Daryn's Avatar
a little more info on the car please. IE mods, miles, latest maintenance..
Old 07-31-2009, 06:55 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Def a missfire.
Drive the car hard to clean off the plugs the shut her down in the area you will be looking in. DO NOT LET IT IDLE, then start pulling every plug to I.D. the rich one.
Old 07-31-2009, 02:29 PM
Daryn's Avatar
make sure the porcelain and make sure its not cracked
Old 07-31-2009, 02:37 PM
SparkyJJO's Avatar
Lick the coil pack to test it.
Old 08-23-2009, 05:46 PM
99 6 speed's Avatar
I can tell you you don't want to try by holding the boot and grounding the plug. A shocking lesson learned at 15...
Old 08-23-2009, 07:16 PM
7camaro7's Avatar
mine failed me at 56,000 due to an exhaust leak after my headers were installed. I had bolts to fall out where the a.i.r. connection goes on the pass side. My pass side plugs were fouled. I bought 8 new plugs and it got better but same ole po300. Bought 8 wires, got better, same ole po300. Bought 4 coils for the pass side. Got better and ultimately swapped the driver's side coils. I replaced all 8 plugs, wires, and then coils then it finally started running like a champ again I made sure to fix that exhaust leak too! and yea don't crack the porceline on the plugs. That'll cause misfires too
Old 08-24-2009, 09:32 AM
8urford2002's Avatar
Same thing happend to my buddy. After we did a header install on his 2002 camaro he had a coil pack go out.
Old 08-24-2009, 07:50 PM
99 6 speed's Avatar
would an in-line tester work on these? otherwise a clip on type would work.
Old 08-27-2009, 09:14 AM
91RS383's Avatar
Ignition Coil Test
1. Disconnect the ignition coil output wire at the distributor cap.
2. Connect a spark plug to the end of the ignition coil output wire which you just disconnected.
3. Connect a ground wire to the threaded portion of the spark plug.
4. Disconnect the ignition coil ground wire from the negative terminal on the coil (Green Wire).
5. Connect one end of a ground wire to the ignition coil negative terminal.
6. Turn the ignition switch to the ON position.
7. Tap the other end of the ignition coil ground wire jumper on an good grounding point (for example the battery negative terminal) and look for sparks at the spark plug that correspond to the frequency of your tapping of the ground wire.
8. If you have a good spark at the spark plug, the ignition coil is good.
9. If you don't get a good spark, check for approximately 12 VDC from the coil positive terminal (black wire) to ground with the ignition switch in the ON position. You should also get approximately 12 VDC from the coil negative terminal (Green wire) to ground
Ignition Coil Resistance Check
In addition to the test above, you may elect to perform an ignition coil resistance check as confirmation of the coil's condition.
1. Check the ignition coil primary coil resistance by connecting an ohmmeter between the positive (Black wire) and negative (Green wire) terminals on the coil. The resistance should be 0.4 to 0.6 ohms.
2. Check the ignition coil secondary coil resistance by connecting an ohmmeter between the coil output terminal and the ignition coil negative terminal. The resistance should be 5000 to 7200 ohms.
strikeone (09-25-2022)
Old 08-27-2009, 01:35 PM
batman911's Avatar
spray them with wd40 , it'll pull the moisture out and tell you if they are bad
Old 09-21-2009, 05:06 AM
mjr_350's Avatar
mate coils do fail.
I have a failed one on my lap now
My LS1 commodore started running like a bitch on 7 cyls and threw a code
P0354
Circuit open, shorted or earther for less than 15 seconds
I started the car from cold the next day and the no4 header pipe had no heat at all after 1 minute of running so its more than a miss fire.
Relpaced it and all is good
I put it down to being too close to the stainless headers after my coil relocation so i have a shield now
Old 09-21-2009, 11:16 AM
98z-28redcamaro's Avatar
my check engine light flashed and turned out to have floated a valve
Quick Reply: How Do you test the coil packs ?
