799 vs 243
Old 07-29-2009, 10:56 PM
jetlag's Avatar
Default 799 vs 243
I've read a lot on here saying 799 heads are the same as LS2 243 heads...
Do they have the exact same specs?
Would they provide the same compression ratio?
If they are the same, why does it seem they aren't as popular?
Old 07-29-2009, 10:59 PM
JonCR96Z's Avatar
They are cast in a different location. That alone probably allows small variances, but nothing really worth mentioning I'm sure. They are only on newer vehicles so there aren't as many out there.
Old 07-29-2009, 11:14 PM
Bader-X's Avatar
243 heads (LS6) came with 2.00 hollow stem intake valves (lighter) 799 (LS2) regular solid 2.00 intake valves
243 came with sodiom filled stem 1.55 exhaust valves (lighter and more heat dissepation) 799 came with regular solid stem 1.55
and this one I`m not sure of but 243 01-04 came with the blue LS6 springs (more lift capable) but 2001 243 and 2005 and later 799 came with yellow LS6 valve springs (less than the blue lift capability)
that`s why 243 heads are much more expensive because of the hollow intake and sodiom exhaust I think.
this is what I understood from reading so anybody correct me if I`m wrong.
and they are popular because most sites write for their ported 243 heads:
*LS6 Style* or 243 or 799 head casting but the title says ported LS6 of 243 heads
Old 07-29-2009, 11:38 PM
JonCR96Z's Avatar
243 is just the casting number. They came with and without hollow stem valves. They are popular because they've been around since 2001 where as 799s have been around since mid 2007.
Old 07-30-2009, 12:20 AM
jetlag's Avatar
Yes, I already know about LS6 243 heads..hah
I was merely asking if there are ANY differences between LS2 243 heads and 799 heads. That is why I specified LS2 in my original post..
Old 07-30-2009, 01:46 AM
jetlag's Avatar
Also, would it still gain about the same 15rwhp as 243s?
Is $200 a good price for fully assembled heads?
Old 07-30-2009, 10:10 AM
JonCR96Z's Avatar
$200 is an awesome price. They are the same as LS2 243s (which sell for $400+).
Old 07-30-2009, 11:17 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Jump on them for $200!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-30-2009, 11:45 AM
Bader-X's Avatar
200$ a steal! get them if you`ll use them without cnc porting or just upgraded springs ..... PRC LS6 stage 1 is the same that is cnc`d with new ls6 springs so better in my opinion if you won`t use them ported
just a thought
Old 07-30-2009, 09:51 PM
jetlag's Avatar
I got them.
When I say fully loaded, I mean fully loaded..hah
Valve covers, rocker arms, rocker arm stands, springs, valves, etc.
Old 07-30-2009, 09:57 PM
JonCR96Z's Avatar
Sweet deal. You should be well in the 10s now.
Old 07-30-2009, 10:00 PM
jetlag's Avatar
I would have already been in the 10s if my bottle didn't go empty..haha
I don't know if I already posted about it or not, but I was having trouble hooking all night, then FINALLY cut an awesome 60ft... The car lost 3mph and still ran an 11.04.
Old 07-31-2009, 02:15 PM
ahartz28's Avatar
Originally Posted by jetlag
I got them.
i hope you gave the guy a reach around! thats a sweet deal!
Qdttracer9 (02-22-2021)
Old 12-03-2010, 12:32 PM
rumblebox's Avatar
so they have the same chamber volume and everything?
Old 12-03-2010, 01:26 PM
01ssreda4's Avatar
This is correct. They are the same heads, provide the same gains and I'm sure they run the exact same CNC program on either head regardless of which one it is. No difference except they dont come on the Z06. That factor alone gives the 243s their "rep".
Old 12-03-2010, 02:31 PM
09camaro383's Avatar
799 heads and ls2 243 heads are the same thing same combustion chambers same exhaust ports D shape Identical if you are look at them that is a good deal 200 assemble!! but I got mines for 80 assemble a lot of people don't know about 799 heads that's why you can find them cheap but they are as good as the 243 heads!!
Old 12-03-2010, 03:01 PM
CamaroZ28_LS1's Avatar
I have 799 heads and I have made decent power with my set up on my Camaro with them on a very mild cam (221/221 561. Lift cam 114+4LSA) 378whp and 369 torque. I just put in a slightly larger cam in last weekend and hope to hit over 400whp.
I payed $400 for my 799 heads that someone put LS6 Valve springs on already. I currently have .650 lift springs in there now.
Old 12-03-2010, 03:03 PM
greenwood's Avatar
799/243 heads, are the same but the 799 has a sand tool chamber, the 243s have a steel chamber tool . so imo the 243 might run a littel better .if they are not ported
Old 12-03-2010, 11:26 PM
studderin's Avatar
thats a great deal. The have a little different surface finish from the way they are casted like ^^^ said. But for porting the casting are the same, but there is still some a little better then others. Mostly how the cast runner fit the seat, some are "under cast" if that makes sense, putting .02 .05 valve can fit that better if you have a few casting your working with. But haven't done enough to notice a difference for sure between a 799/243
Old 12-04-2010, 03:22 AM
Zmg00camaross's Avatar
What do the 799 come off of? model of car and engine?
Quick Reply: 799 vs 243
