Bad Lifters. How long?
Old 07-20-2009, 07:55 PM
mlbz28's Avatar
Default Bad Lifters. How long?
Alright so my lifters are bad and I was wondering if there was any kind of "time frame" before it gets REAL serious. Im saving up to fix it but I was really just wondering if anyone could give me a time frame. Thanks!
Old 07-20-2009, 07:59 PM
chaman's Avatar
If you dont abuse the car a "bad" lifter could last sometime...how bad are we talking? Consider doing a cylinder compression test to see if there is also something more apart from lifters.
Old 07-20-2009, 11:44 PM
mlbz28's Avatar
You can hear the lifters but after the car warms up and i start driving, the noise fades away so im assuming its not too bad.
Old 07-21-2009, 12:04 AM
chaman's Avatar
What's the mileage on your car? You recently changed the engine oil? Go for a thicker grade...maybe that will help to keep the lifters filled with oil overnight and take care of that noise.
Old 07-21-2009, 09:08 PM
mlbz28's Avatar
I got 47,xxx, and i changed my oil about a couple hundred miles ago and went with 10w30 i think, ill have to double check on that
Old 07-21-2009, 09:17 PM
jsmith309's Avatar
It's most likely "piston slap". LS1s are notorious for it. You have no worries, mine does the same thing. Now if its REALLY loud u may have a problem, but i believe LS1s are aluminum and u can hear more going on, unlike cast iron
Old 07-22-2009, 07:34 PM
mlbz28's Avatar
Alright is there anyway to know FOR SURE if it's piston slap or lifters?
Old 07-22-2009, 08:25 PM
jsmith309's Avatar
I'm pretty sure if it goes away after like 5-10 mins, it's piston slap. Only use synthetic oil with these motors. a bad lifter would soung really high pitched and would most likely Always tap and not go away after its warmed up. but ALWAYS let it warm up before getting into it
Old 07-22-2009, 09:06 PM
mlbz28's Avatar
Alright and it goes away most times some days its more distinct than others but it's just noisy when it's cold. And yea i always let it warm up
Quick Reply: Bad Lifters. How long?
