Drag Racing Tech
Setting up a Accufab 4500
Old 07-10-2009, 12:44 AM
chrismcdaniel's Avatar
Default Setting up a Accufab 4500
Ok, so i was looking for a 4150 to run on my 408 with a vic jr. intake, im switching from a 90* elbow. Well, i got a 4500 accufab instead, and it came wit hthe 4500 to 4150 adapter. BUT DAMN THAT ***** TALL. I dont mind finishing the hack job on my cowl, but does anyone have any pics of this complete? even if i completely remove my cowl up to the winsheild, will it even fit?? the adapter itself is 2" think
help a brotha OUT
Old 07-10-2009, 01:09 AM
i think that if i cut the cowl back to the windsheild, it will fin.. i have a 4" hood so thats not a problem.
BUT DAMN thats tall
Old 07-10-2009, 04:15 AM
69_YENKO's Avatar
not my car, but heres some pics i saved for when i setup my Vic jr with an accufab tb
hope they help
Attached Thumbnails Setting up a Accufab 4500-ab1.jpg   Setting up a Accufab 4500-ab2.jpg   Setting up a Accufab 4500-ab3.jpg   Setting up a Accufab 4500-ab4.jpg
Old 07-10-2009, 01:42 PM
Camaro396's Avatar
I use a 4500 TB with the adapter plate and it fits fine. I have a big cowl hood though.
Old 07-10-2009, 04:32 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Finally some pictures.
Old 07-10-2009, 05:13 PM
thanks guys. yea i have a 4" cowl too, so thats not a problem. Im going to hack the rest of the wiper cowl out, and it should be good. Next, im pulling the motor to get the car to a chasis shop to do the 12 cage, chasis, and suspension work. while thats being dont ill figure out the nitrous set up. I guess im going to go with the Big Shot 2 stage set up. ill update with pics as it goes. Im also takeig everything i can out of the car to getthe weight down. wish me luck. iv had this car for 9 years and it has went from dd to everything in between that and what is becoming. cant wait to see some single didgets finally
Old 07-10-2009, 05:15 PM
Race your car!
JL ws-6's Avatar
If you have a good local fab guy, ya could have the 4150 flabge milled off the intake, have the 4500 welded onto it, and then just port the opening to smooth it back out.
With a bridgeport, someone that's good at welding alum, and a little work you can put a 4500 on just about any intake.
I've already seen 2 done this way, so I know it will work
Old 07-10-2009, 05:22 PM
does sound like a great idea, but im not sure of anyone around me i would trust to do it. i might have to look around or possibly just ship it out to have it done.
Old 07-11-2009, 08:32 AM
Race your car!
JL ws-6's Avatar
I'd look into it. All someone has to do is put the intake on a bridgeport, have the 4500 flange in hand, notch the intake (milling the old one off pretty much) for the 4500 flange, then weld it on the inside and outside.
Report it a little bit to smooth where it was welded, and you're good to go.
Probably can call LME I see you had them build the motor...they probably can do it I'd think, if not they for sure have someone that can.
Old 07-11-2009, 12:39 PM
35th SS's Avatar
help a brotha OUT
Damm brother didnt know your back in the mainland already.I see the car is getting a different setup .looks good and Im sure youll figure it out.
Old 07-11-2009, 02:42 PM
Yea man, been here a minth already. Missing hawaii, but at least ill have a track
Old 07-11-2009, 03:16 PM
35th SS's Avatar
Ya I hear ya.just comeback whenever you can or visit.the oldtimers are still here like Larry and alot of new peeps.BTW Vengeance racing is down here tuning a bunch of cars from the site.I envy you for having a track to go to.we might have something in a year or to concerning the track here.will see.ok back to your topic.good luck Chris.
Old 07-11-2009, 07:03 PM
OWN3D BY MY PROF!
I've though about doing that. I saw an accufab 4500 on here for less than I could get a 4150 TB new so I was considering it. The only thing that held me up was the fact that I wasn't sure if the 4500 had a larger diameter than the 4150 and the fact of trying to fit a hat on it. I would think that it is as the 4500 has 2.25 plates versus the 4150's 1.75 plates.
I'm still considering it, but need to figure out a few facts first. My super vic and fuel rails should be on their way to my house now so it is getting down to decision time.
Old 07-15-2009, 11:46 PM
OWN3D BY MY PROF!
OK, I just got my super vic in the mail today. For some odd reason my super vic has no provisions for intke manifold gaskets. I reaad the directions and it says you have to use a specific intaake gasket, but there's no spot for them. Thoughts? I'll post a picture tomorrow.
Old 07-16-2009, 02:02 AM
69_YENKO's Avatar
A carbed intake and carb/carb style TB do not use an o-ring to seal like our factory TBs they just use a standard flat cork/rubber/paper gasket sandwiched in between the tb and intake. with it being a 4500series TB that gasket may need to be ordered form jegs/summit. a regular 4150 gasket can be had at most any parts store.
EDIT, nevermind I read your post too fast, your asking about the intake port gaskets, not sure what to tell you, I thought they were machined with a groove for the o rings.
Old 07-16-2009, 02:59 AM
jmill96Z's Avatar
Here's a couple pics of mine 4150 flange:
Old 07-16-2009, 03:02 AM
jmill96Z's Avatar
That's crazy. My vic Jr has the intake gasket flanges. Wonder why they changed with the Super Vic?
Old 07-16-2009, 07:38 AM
ATVracr's Avatar
We had to make our own gaskets for the super Vic., same thing with Cary's intake.
Old 07-16-2009, 12:28 PM
OWN3D BY MY PROF!
When I bought it that is what I was expecting, but upon seeing it I was slightly shocked to not see the machined grooves. For some odd reason it doesn't have them. It says, "Manifold #28095 (super vic) uses a conventional style gasket, fel-pro #1312-3".
Did you guys try the fel pro gaasket listed above in the directions? If so why did you end up making your own?
Old 07-16-2009, 01:55 PM
ONEBADWS6's Avatar
They had cracking issues with the O-ring style and switched to a paper style in the begining of the year.
Quick Reply: Setting up a Accufab 4500
