How can you tell if you have a bad lifter? Inside please.
Old 02-17-2003, 10:16 AM
Speed Demon's Avatar
Default How can you tell if you have a bad lifter? Inside please.
Over the past couple of weeks my car's valvetrain has been getting more noisy. Almost like a rattle sound coming from one cylinder or valvetrain on one cylinder. I thought it may be valve springs getting weak. Now it has gotten worse. You can hear it outside the car while it's idling. The car still runs good and is not missing or stumbling.
The sound is hard to describe, almost like someone rubbing a rock on a chalk board. It makes the noise once with every revolution of the engine and increases frequency with engine rpm. It is not a ticking sound, not like a bent pushrod sounds. The car has constant 38 psi oil pressure at idle.
I thought it may be a lifter. How can I check without pulling the heads? What else can I check?
The engine has approx. 50k miles on it and 30k of those were with a T1 cam. Mostly street driving. I have been running MMS valve springs for about 25k and they have 150-160lbs seat pressure and 360-370 open pressure.
Your suggestions please.
Thanks.
<small>[ April 16, 2003, 10:37 AM: Message edited by: Speed Demon ]</small>
Old 02-17-2003, 11:19 AM
HOSS99's Avatar
Default Re: How can you tell if you have a bad lifter? Inside please.
It sounds as if one of the lifters is not pumping up. I don't think there is any way to confirm other than sound, and misfire codes without pulling the head. I had a lifter go bad on my SS shortly after a b1 cam was installed, and it sounded exactly as you are describing. I went with the regular Comp-Cams lifters (not the R's, R's are noisy). So far so good.
Old 02-17-2003, 11:32 AM
Would more misfire codes on one cylinder possibly indicate a bad lifter?
Old 02-17-2003, 01:15 PM
HOSS99's Avatar
Yes, but you would still get misfires on the adjacent cylinders.
Old 02-17-2003, 01:54 PM
Ok, I'll have to autotap it and see what I find.
Thanks,
Brandon
Old 02-22-2003, 03:49 PM
I Atapped it. No misfires once above idle.
I pulled all the rockers checked them and checked the springs. Pushrods are good too.
How else can I tell if it's a lifter?
Will it mess anything up driving it.
Old 02-22-2003, 03:56 PM
Cal
Cal's Avatar
Maybe the crankcase is just low on oil; that can cause the lifters to not pump up and sound just like that.
<small>[ February 22, 2003, 03:57 PM: Message edited by: Cal ]</small>
Old 02-22-2003, 07:00 PM
Nah, I checked the oil. It sounds like only one lifter, or one something. I am not sure, but it's getting louder.
Old 02-23-2003, 07:25 AM
LS1derfull's Avatar
Put each cylinder on tdc of compression stroke and check rockers for unusual play or give by pushing down on them. If you have a deflated lifter you should be able to feel it compared to others.
Quick Reply: How can you tell if you have a bad lifter? Inside please.
