4l60e Shift linkage?
Old 06-01-2009, 02:21 PM
My95Z's Avatar
Default 4l60e Shift linkage?
To make a long story short, just rebuilt my 4l60e put it back in the car and now it only moves forward almost like the linkage is off. I broke the little internal shift rod putting it back on so I went to the local trans shop to get a new one and it was longer than the stock, could this be the problem?
I didn't know they switched lenghts depending on years. Reverse acts like OD, Drive like 2nd and so on, but park still works fine...
On a 95 4l60e
Old 06-01-2009, 07:16 PM
My95Z's Avatar
Heres the broken one.
Old 06-17-2009, 11:16 PM
warrencj's Avatar
ditto on this problem. i was coming home from the track tonight and stupidly neutral dropped off of a redlight. everything was fine until i got to 7-11 and the car went forward when i put it into reverse. anyone have any info?
Old 06-17-2009, 11:34 PM
My95Z's Avatar
That sounds like something else is wrong...mine was the wrong part after/during a rebuild, the one they gave me was too long.
I ended up cutting it down and putting the same bend in it as the old one to "close out this thread" and it worked fine.
You may want to pull the cover off under the shifter and see if the cable is good, it has little ears or sides on it and if it gets broken the car won't go into the right gear.
Old 06-17-2009, 11:47 PM
warrencj's Avatar
thanks for the quick reply. i will definately check that tommarow.
Old 06-17-2009, 11:54 PM
My95Z's Avatar
Hope thats all it is for you, other thing would be something lock up in there like forward clutches. May want to jack up the car and see if what gear you select is actually what is moving on the side of the trans.
Old 06-18-2009, 05:45 PM
warrencj's Avatar
trans and shifer are moving in the same pattern so i guess that means that i'll be dropping the trans out and probably getting annother...no bueno. it's my DD and i just blew all my money on a laptop for school.
Old 06-18-2009, 05:58 PM
My95Z's Avatar
Sorry to hear that man, I know trans problems are no fun.
Quick Reply: 4l60e Shift linkage?
