spool difference between turbonetics t76 with p trim vs s trim turbine
Old 03-24-2009, 02:33 AM
unclebens's Avatar
Default spool difference between turbonetics t76 with p trim vs s trim turbine
Any body have a good idea on the spool difference between the turbonetics t76 with the p trim (now called f1 65) vs s trim turbine (f1 68) . I have a stock ls1 6 speed.
Anyone max out the p trim and need to upgrade to the s? If so at what whp level did you max it out?
Old 03-25-2009, 11:43 PM
unclebens's Avatar
Anyone with experience with the p trim and s trim difference on the same turbo . Either with t70, t72, t76 or t78?
Old 10-23-2009, 11:22 AM
unclebens's Avatar
bumpedy bump
Old 10-23-2009, 11:34 AM
omore001's Avatar
An S-trim will make more power than a P-trim on an LS1. P-trim should spool faster but will be useless at the higher RPMS.
P-trim + LS1= serious restrictions
Do not misunderstand, P-trim can make decent power on LS1 and many here do, but it is not the most efficient route.
Quick Reply: spool difference between turbonetics t76 with p trim vs s trim turbine
