Are bmw and chevy rims 5x4.75 bolt pattern?
Old 03-13-2009, 09:33 PM
9t8z28's Avatar
Originally Posted by 02SS0384
Yea, goes on the hub and into the wheel to take up the space.
Old 03-15-2009, 01:21 PM
OMGaZ28's Avatar
Originally Posted by 12secSS
0.7mm = 0.028"
That is the equivalent to 5 sheets of standard 8-1/2 x 11 printer paper (one sheet is 0.004" thick). It is minescule!
OMGaZ28,
GM and BMW are not the same company, nor are they in the same country and do not use the same units of measure. GM uses Standard American units like inches and feet, where as BMW being in Germany uses Metric units (such as millimeters and meters) like most everyone else. It is mere coincidence that there lug patterns are similar. This is why they possibly didn't collaborate when they were initially designing their wheels, to ensure we could use BMW wheels on GMs and vice versa.
i never said they were the same company, i just ment that GM uses 5x120 also.
Old 03-15-2009, 01:23 PM
OMGaZ28's Avatar
Originally Posted by ChevyChad
LMFAO at people being paranoid at 0.65mm... For crying out loud, mechanical pencil lead is .7mm! Some people are idiots. The Alchemist is 100% right. Factory tolerances on the wheel hubs are far greater than that difference I promise!
I dont see a reason for name calling. And in the end everyone is going to do whatever they want regardless of what anybody else says.
Old 03-15-2009, 07:08 PM
evilZO6's Avatar
Here's mine. Actually, I no longer have them installed.
Where did you get those? If youre not planning on using them anymore are they up for sale?
Old 03-15-2009, 07:33 PM
02SS0384's Avatar
You can get them at 1010tires, the ones I have came with the wheels. They fit too tight in the wheel and when I tried to take the wheels off it was a PITA, so I need to get smaller OD rings. Trying to get the tire off on the side of the road after a flat would not be fun with those rings installed!
Old 03-15-2009, 08:23 PM
9t8z28's Avatar
Your car looks great! Anymore pics of the RPM 505's?
Sorry to thread jack
Old 03-15-2009, 09:20 PM
wabmorgan's Avatar
0.7mm = 0.028"
Not to be an ***..... but .7mm is the same thickness(width) as a .7mm lead for a .7mm mechanical pencil.
As you said though... It is minuscule!
Old 03-16-2009, 04:34 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Sorry if you got offended, but I just call it like I see it. And you are wrong BTW. a 120mm bolt pattern will NOT bow the studs because there is ample clearance on the bolt holes in the wheel. Have you ever tried to mount a 5x120mm wheel on a 5x4.75" hub? I bet not because if you had, then you would know better. I also bet that you would not be able to tell the difference in the 2 patterns if you had both in front of you... Even if you had a tape measure! Again, not trying to offend you man, so dont take it like that. I'm just sayin that there is virtually no difference and it should not be of concern at all.
Old 03-16-2009, 06:48 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Google is your friend for finding hubcentric rings....
Old 03-16-2009, 07:57 AM
wabmorgan's Avatar
Tape measure no... micrometer.... would be another story.
However there is probably enough "play" in the bolt holes that the .7mm difference doesn't really matter.
Old 03-16-2009, 10:21 AM
02SS0384's Avatar
https://ls1tech.com/forums/wheels-ti...505s-here.html
Old 09-14-2017, 09:31 PM
  #32
Pweir86's Avatar
Default Wheels dont fit????? Help
So i got some 5 by 120 aftermarket wheels for my bmw it even says bolt pattern on the back of the wheel and i was told that my bolt pattern is the same so i looked it up and sure enough it was. I can fully install 3 lug studs then the other two are on the outside of the hole in the wheel tried loosening other 3 almost all the way out and still cannot get other two started. ive been working on cars for 15 years and never had this problem. So is the wheel made wrong?? Or am i doin something wrong that i dont know... Lol!!!
Old 03-19-2022, 09:33 PM
  #33
JONATHANSIGLER7's Avatar
Default BMW GT1 19 inch rims on 2002 Chevy Blazer
I’m running 19 inch BMW BP GT1 rims on my 2002 Chevy Blazer and the only thing I’ve noticed about the light difference in the BP is you just have to hand tighten each lug slightly or it’ll make them be off centered but other than that I never had a problem with them coming loose or anything. All I would say is if your do run some it’s just like any other maintenance on your truck/car just check it every so often.
Quick Reply: Are bmw and chevy rims 5x4.75 bolt pattern?
