Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
95 camaro v6 5speed 350 swap
Old 02-06-2009, 01:51 AM
polaris21's Avatar
Default 95 camaro v6 5speed 350 swap
ok im looking at getting a 95 camaro v6 with a 5 speed, and my goal is to put a carborated 350 in it. How hard is this swap? Im looking for a project but not one that will take me years to complete. Will a 350 even bolt into the car? Will this tranny bolt to the 350 without mods? What motor mounts do i need? how much fabrication skills will be need? Thanks any help will be appreciative.
Old 02-06-2009, 04:13 AM
LT1
LT1's Avatar
What trans do you plan to use? The 350ci engine will bolt right up.
Old 02-06-2009, 09:02 AM
camaroboricua's Avatar
I dont know if the mounts are the same for a 6cyl as they are for an LT1 but if you have LT1 motor mounts it will bolt right up. As far as the tranny goes I think the 4th gen t-5 will not bolt up to the 350. I used a t-5 for a third gen with a t-56 crossmember. Do a search through here, there are several posts about this stuff. The only cutting I had to do was to the upper firewall to get the distributor to fit.
Old 02-08-2009, 12:15 PM
EastTnZ28's Avatar
Just do it. You want know everything til you do it yourself. Sounds like a pretty good way to have a cheap fast car and those two things are hard to find. Good luck.
Old 02-11-2009, 09:11 AM
86MCSS's Avatar
Is the 4.3 v6 in it now? if so it will go in because the 4.3 is pretty much a 2 bolt main 350 with 2 less cylinders... we put a 350 in my neighbors s-10 that had a 4 cyl orginally... and the motor mounts will be the same for the 6cyl and an lt1 b/c in my car i have pretty much an lt1 block w/o reverse cooling flow and we used old 350 motor mounts and i kno the v6 and the old 350 mountes work.... the only problem i see is the tranny.. i would do research on what trannys fit what
Old 02-11-2009, 09:23 AM
XtremeModifier's Avatar
Well, if I can't get my own car fixed up I might consider selling you my motor. You'll start with a stroked and poked 350 (389 bore/stroke) and a 700r4.
Quick Reply: 95 camaro v6 5speed 350 swap
