Last edit by: IB Advertising
- Camaro and Firebird How to Repair Wrap Dash<br>Step by step instructions for do-it-yourself repairs.
how to fix or wrap your dash pad to look brand new
tired of that cracked and broken dash then fix it...
how to fixed your cracked dash pad to look brand new!
OK here it is.
Vinyl 2 yds your choice of color
spay adhesive was $7.99 at Advance Auto Permatex Heavy Duty blue and orange can.
Plastic welder epoxy $4.99 AZ and we find it at Walmart $2.88, after I had already opened it..sucks
1. you need to fix the broken part of the dash with the plastic welder
2.I used cardboard and epoxy to glue the cracks back together, sand the plastic then patch the crack permanently
the cardboard adds great strength to the already strong glue, not pretty, but this will never be seen anyways.
3.SPRAY ON adhesive!, follow directions for max strength. Spray both vinyl and dash pad 2 good coats. let dry for 5-10 mins until tacky, then press on firmly. TAKE YOUR TIME, start in the middle and work you way out getting all the air bubbles out( hair dry works great)
flip over trim edges leaving enough overhang
now with the over hang I used a hot glue gun to hold it down works great and drys fast..
trim the rest to fit and finish folding over the flaps,
brand new dash!!!
The best part of this vinyl is that its flexible, and will withstand direct sunlight while providing support for the cracked dash underneath.
Enjoy your sweet newish dash pad without the cracks!
If I missed anything let me know and I'll try to answer your questions, I'm not really good on writing these how to's....lol
also with the left over vinyl you can pretty much wrap anything in the car,
OK here it is.
brand new dash!!!
I just cut around the vent (with a razor) leaving a little extra to hand over and be pushed down, the bars are not coved in vinyl, I didn't think about trying to do them until it was to late, it maybe possible to do them it would just be real time consuming
oh i see. looks so sweet i can't wait to do this. i wonder how suede would look? how is the shine on the vinyl? you know how when you drive around and it's sunny the glare coming off the plastic is horrible lol
My only complaint with the adhesive is that when it gets REALLY hot out, the glue seems to loose its tack. I had my radio bezel wrapped with the strongest adhesive money could buy, and it still got droopy and lost its tack in the summer heat.
I guess if your in an area where it doesn't get over 90 out it's very worth it.
Excellent write up too! I'm sure this will help a LOT of people out. Thanks for the contribution
