99-02 fbody pcm pinout vs 99-02 truck pinout
Old 01-23-2009, 11:37 AM
sman's Avatar
Default 99-02 fbody pcm pinout vs 99-02 truck pinout
Im doing a swap and got a computer with my engine (5.3) but its going in a 99 camaro using its harness, I do NOT have the 5.7 pcm as the car started life as a v6 car. Can I just use the 5.3 pcm no problems or are the pinouts different? (fingers crossed)
Old 01-23-2009, 12:54 PM
slow's Avatar
99-02 pcm's all share the same pinout, if it is a 09354896 or 12200441 service number unit.
Ryan
Old 01-23-2009, 01:07 PM
sman's Avatar
So I should be able to use a 99 z28 harness with a 5.3l and computer no problem?
Old 01-23-2009, 01:58 PM
slow's Avatar
yes.
Ryan
Old 01-23-2009, 01:59 PM
12secSS's Avatar
Yes, just be sure you flash the appropriate V8 F-Body calibration to the 5.3L ECM, so it knows what signals to expect and which one do not apply.
Old 01-23-2009, 02:36 PM
sman's Avatar
Just have them flash to a 99 ls1 and change the displacement to 5.3 instead of 5.7? What would some one charge for something like that and removing emissions and adding headers?
Old 01-23-2009, 03:36 PM
12secSS's Avatar
Yup, that is all you need. they should only charge you $50 or less.
Old 01-24-2009, 09:46 AM
sman's Avatar
Who does these services?
Old 01-24-2009, 07:52 PM
SS SLP2's Avatar
good service from "waite4me" per mailorder
Johnny
Old 03-26-2009, 11:29 AM
02dime's Avatar
can some let me know what pinouts control the fans, im having a problem with the efans the ecm is not turning them on period, im using a pcm from a 2002 sierra 5.3, any help is appreciated thanks
Old 03-26-2009, 12:13 PM
12secSS's Avatar
The Sierra did not use E-Fans, so you would need to turn that on in the calibration. Also you will only have control of one fan with the computer, as the second fans pinout is used by the HVAC. You will need to route to the A/C wire, do a search on Performancetrucks.net to find the pinout and/or A/C wire needed to tap into.
Old 03-26-2009, 03:38 PM
Mike454SS's Avatar
Best bet is to do as has been suggested and have the PCM flashed with a 99-2002 Camaro Z28 base file (I'd choose the 2002 myself, it's the best operating system that'll work in a 99-2002 PCM), with the appropriate calibration stuff copied over from the 5.3 (spark, fuel, VE and so on)...then use a stock Z28 harness and don't re-wire anything.
Old 04-09-2011, 02:14 PM
richard_lyew's Avatar
hi all, does anybody have the PCM/ECU/ECM pinout for the 1999 GMC Yukon Denali V8?
Quick Reply: 99-02 fbody pcm pinout vs 99-02 truck pinout
