Re-use camshaft sprocket bolts?
Old 01-02-2009, 06:47 PM
1.8t's Avatar
Default Re-use camshaft sprocket bolts?
I know everyone says to buy new or go ARP for the head bolts because the stockers are torque to yeild bolts. However, I have never heard anyone say to buy new camshaft sprocket bolts instead of re-using the existing ones. Only reason I ask is because I bought the GM service manuals for my vette and according to them, the camshaft sprocket bolts are TTY as well, which would mean I would need new ones for re-installation, correct?
Old 01-02-2009, 07:13 PM
JFM-jr's Avatar
My manual states 26ft lbs . . . .
Old 01-02-2009, 07:24 PM
1.8t's Avatar
For the Camshaft Sprocket Bolt <- Actual title listed in my manual, it states 55 lbft on the first pass and then 50deg on the second pass. Did GM change the installation procedure on the LS3?
Old 01-02-2009, 07:26 PM
JFM-jr's Avatar
Ahh sorry bro totally my fault i'm giving LS1 specs. My apologies......
Old 01-02-2009, 11:23 PM
405HP_Z06's Avatar
Are the cam sprocket bolts still M8 x 1.25 on the LS3? If so, they will break with 55 lb/ft of torque.
If they are truly TTY than they need to be replaced; however, I doubt they are TTY.
Old 01-03-2009, 12:57 AM
1.8t's Avatar
Yes, they are M8 x 1.25. I think I know the issue. Even though this friggin manual is for my car, they obviously did not incorporate all of the changes that took place with the LS3. Either that or Vengeance put in the 3 bolt cam gear from the LS7 on the car.....not sure. The torque specs being listed I believe are for the single bolt cam gear. Since mine is the 3 bolt, so I will be using the LS7 specs which show the tq to be 18 lbft.
405HP Z06, can you verify this tq amount for me?
Old 01-03-2009, 01:04 AM
405HP_Z06's Avatar
I show 26 lb/ft. This is what I torqued mine to during my cam swap.
Old 01-03-2009, 01:09 AM
1.8t's Avatar
Well I am going with 26 then. Stupid manual says the LS7 bolts should be tq'ed to 18lbft. I doubt 8 more lbft will make a difference.
Old 01-03-2009, 01:26 AM
racer7088's Avatar
Its into steel instead of aluminum so you can go a little over 18 ft lbs. for sure. I do about 25 on those as well with blue loctite.
Old 01-03-2009, 08:06 AM
LS1Tech Sponsor
Robin L's Avatar
The stock LS3 used on very large SINGLE bolt hence the 55 pound initial then the angel for the TTY.
If your LS3 has 3 bolts then someone changed to a LS2 Cam gear to work with the aftermarket 3 bolt cam.
Robin
Old 01-03-2009, 11:52 AM
1.8t's Avatar
Ah, vengeance must have done that for my cam install. Thanks for the help everyone
Old 01-03-2009, 12:56 PM
squarehead's Avatar
LS2s are 18 ft-lbs
Old 01-03-2009, 06:03 PM
Ron@Vengeance's Avatar
We did Your cam was installed before Comp introduced their single bolt camshafts.
Give us a call if you need anything Michael
Old 01-04-2009, 01:31 PM
1FastBrick's Avatar
18 here too... but I Always go 20 and blue loctite.
Quick Reply: Re-use camshaft sprocket bolts?
