Drag Racing Tech
Outlaw's 10.5w true tire width size?
Old 12-29-2008, 07:22 PM
gangbang malloy's Avatar
Default Outlaw's 10.5w true tire width size?
maybe some of the outlaw guys can answer this question. what is the true width of the tire the Outlaw 10.5 class allows? they say they can use a 10.5w tire which means its wider than the normal 10.5 tire but how wide?
i run a 26x11.5x15 MT ET street DOT tire that turns out to be around 275/50/15 for all the drag radial guys and i must say my tire looks pretty narrow compared to the 10.5w tire. any insight fellas?
Old 12-29-2008, 07:38 PM
xpndbl3's Avatar
www.mickeythompsontires.com
Old 12-29-2008, 08:07 PM
ive seen that and thats just the thing the 10.5w tire is more like a 11'' tire and even then they still look like they are wider than my 11.5 tires.
Old 12-29-2008, 08:56 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
It depends on size of particular tire and the rim you run it on.
Old 12-29-2008, 09:25 PM
xpndbl3's Avatar
they show section width and tread width. those are the sizes you need to know. compare the various tires on there.
Old 12-29-2008, 10:01 PM
promod1955's Avatar
It's 11 1/4" on a m/t. Keep in mind your outlaw 10.5 tire is also 33" tall.
M/t makes a killer 28x10.5 and 29.5x10.5. This is what most guys use in limited street and true ten five races.
Old 12-30-2008, 06:29 PM
they say the 10.5 tire is recomended for a 10 inch rim. is it possible to use a wider rim to get the most out of the width of the tire leaving a wider foot print?
Old 12-31-2008, 09:54 AM
promod1955's Avatar
you can put a tt5 on a 12" and a w on a 16"
Old 12-31-2008, 02:07 PM
tektrans's Avatar
Usually manufacturers will say the rim size should be plus or minus up to 1" of the actual tire tread width.
Old 05-25-2017, 04:11 PM
eaglelover200359's Avatar
hello anyonehere
Old 05-25-2017, 04:15 PM
is a 29/10.5 tire wider then a 295/50/15 on 10 inch cragars
Old 04-01-2021, 11:22 PM
Josh LSA's Avatar
14.75 inches to be precise.
Old 04-02-2021, 09:15 AM
MIAmotorsports's Avatar
You can use a 13in rim on a 28 tt5 tire with a beadlock. The 33x 10.5w can go on a 15in wide rim. The wide rim adds an extra inch to the tread on a 10.5w. Then add in the fact of the 33 being 5in taller. They really are two TOTALLY different tires.
dw456post (04-03-2021)
Quick Reply: Outlaw's 10.5w true tire width size?
