How do you change lock/unlock settings?
Old 12-24-2008, 11:23 AM
wannafbody's Avatar
Default How do you change lock/unlock settings?
I want to change modes so that the foglights don't flash when I lock and unlock? How do I do this?
Old 12-24-2008, 12:10 PM
9000th01ss's Avatar
You have to turn the foglights off at the switch. It flashes the parking/running lights, if the fog light switch is on they're going to flash too.
Thats going by the owners manual. Maybe someone else knows something.
Old 12-24-2008, 02:04 PM
ghardester's Avatar
That's right, if your fog lamps are turned on they will flash with the other lights. If turned off they won't.
Old 12-24-2008, 02:26 PM
eseibel67's Avatar
Entering Programming Mode
To program any feature, your vehicle must be in the
programming mode. Follow these steps:
1. Put your key in the ignition.
2. Turn the ignition to RUN to disarm the content
theft-deterrent/alarm system.
3. Turn the ignition to OFF.
4. Remove the RADIO fuse. This fuse is in the
main fuse block, located on the left side of your
instrument panel. See “Fuses and Circuit Breakers”
in the Index.
5. Turn the ignition toward you to ACC.
6. Count the number of chimes you hear. You will
hear one or two chimes depending on the features
your vehicle is equipped with. Refer to the chart
shown previously.
You can now program your choices.
To exit the programming mode, follow the steps
listed under “Leaving Programming Mode” later
in this section.
Exit Lighting and Delayed Illumination
With exit lighting, your interior lamps will come on
for up to 25 seconds when the key is removed from
the ignition.
With delayed illumination, your interior lamps will
come on and stay on for up to 25 seconds when
entering your vehicle and up to five seconds when
leaving your vehicle.
Programmable Modes
Mode 1: Both Off
Mode 2: Delayed Illumination Only
Mode 3: Exit Lighting Only
Mode 4: Both On
When your vehicle was shipped from the factory, it was
programmed in Mode 4. The mode to which the vehicle
has been programmed may have been changed since it
left the factory. To determine the mode to which your
vehicle is programmed or to program your vehicle to a
different mode, do the following:
1. Turn the courtesy lamps on by turning the instrument
panel brightness control all the way up.
2. Count the number of chimes you hear. The number
of chimes tells you which mode your vehicle is set
for. (If you do not wish to change the current mode,
you can either exit the programming mode by
following the instructions later in this section or
program the next feature available on your vehicle.)
3. Turn the courtesy lamp switch off to change the
current mode.
4. Turn the courtesy lamp switch from on to off until
you hear the number of chimes that corresponds to
the mode selection you want.
The mode you selected is now set. You can either exit
the programming mode by following the instructions
later in this section or program the next feature available
on your vehicle.
Last Door Closed Locking and
Lockout Prevention
These features are designed to help prevent your keys
from being locked in your vehicle.
Programmable Modes
Mode 1: Both Off (Doors will lock/unlock when you
press the power door lock switch.)
Mode 2: Lockout Prevention Only (If you leave your
keys in the ignition and leave through the driver’s door,
you won’t be able to lock the doors with the power door
lock switch.)
Mode 3: Last Door Closed Locking Only (If the power
door lock switch is used to lock the vehicle while any
door is open, you will hear three chimes. The doors
will not lock until after all doors are closed.)
Mode 4: Both On (This combines Mode 2 and 3.)
programmed in Mode 2. The mode to which the vehicle
1. Press the power door lock switch on the door.
3. Press the power door lock switch again on the door
until you hear the number of chimes that corresponds
to the mode selection you want.
on your vehicle.
Remote Keyless Entry Verification
This feature provides feedback when the vehicle
receives a command from the remote keyless
entry transmitter.
Programmable Modes
Mode 1: All Off (The headlamps will not flash and
the horn will not sound to provide you feedback that a
lock/unlock command has been received by the remote
keyless entry transmitter.)
Mode 2: Horn and Lamps/Lamps (Your horn will sound
briefly and your parking lamps will flash when you press
LOCK on the remote keyless entry transmitter. Only your
parking lamps will flash when you press UNLOCK.)
Mode 3: Horn and Lamps (Your horn will sound briefly
and your parking lamps will flash every time you push
LOCK or UNLOCK.)
Mode 4: Lamps (Your parking lamps will flash every
time you press LOCK or UNLOCK.)
Mode 5: Lamps/Horn and Lamps/Lamps (Your lamps will
flash upon the first press on LOCK, your lamps will flash
and your horn will sound upon the second press on LOCK
and your lamps will flash upon any press on UNLOCK.)
programmed in Mode 5. The mode to which the vehicle
1. Press the UNLOCK button on the remote keyless
entry transmitter.
3. Press the UNLOCK button, again, on the remote
keyless entry transmitter until you hear the number
of chimes that corresponds to the mode selection
you want.
on your vehicle.
Old 12-24-2008, 04:59 PM
wannafbody's Avatar
Yep, it can be done on TA's if you want to install HID fogs. Thanks, I tried reprogramming it but what I failed to realize was that the beginning sequence of putting the key in and removing the radio fuse was a couple pages back in the owners manuel. I couldn't get the chimes and couldn't figure it out.
Quick Reply: How do you change lock/unlock settings?
