How to tell if fuel pump is going bad?
Old 12-02-2008, 07:39 AM
14 Second Truck Club
Hemi Killer's Avatar
Default How to tell if fuel pump is going bad?
Mine is whining like crazy and is pretty loud. Is this a sign of pump failure?
Old 12-02-2008, 07:41 AM
deelong4002's Avatar
Yeah it can be. Have you checked the fuel filter?. Mine was whining last year and i changed the filter and it quit. But im sure it shortened the life of mine significantly.
Old 12-02-2008, 08:09 AM
Badhawk's Avatar
When my pump when out last year, the truck started skipping and sputtering.
Only took about 10 miles before I was stuck on the side of the road.
Try to keep atleast 1/2 a tank of fuel. The pump is actually cooled by the fuel, henceforth making the life last longer.
Old 12-02-2008, 09:05 AM
Sigforty's Avatar
If the fuel pump is going bad you should be able to see it with a pressure guage. You need to hook up a guage where you can see it in the vehicle. Then go out and do some wide open throttle passes. As you get up in the rpms you should see the pressure drop significantly.
Old 12-02-2008, 09:32 AM
SOMbitch's Avatar
There is a Schrader valve on the fuel rail to hook a guage in and it should idle at 58-59psi.
My ex's Suburban had a loud a$$ pump but it never went out in the 66k we had it. My Z-71 pump whines sometimes but I am not really worried about it.
Old 12-23-2008, 03:51 AM
If I hook a guage to it at idle and tape it to the windshield. Put it in drive, and it starts surging, (which is what happens if I don't let it warm up for awhile) Should the pressure hold steady or drop slightly due to the rpms surging? I would think it should hold steady, but don't know.
A link to the other post: https://ls1tech.com/forums/generatio...-my-motor.html
Old 12-23-2008, 09:12 AM
01ssreda4's Avatar
suburbans have notoriously loud fuel pumps. ridiculous but they keep working.
Old 12-23-2008, 09:33 AM
Sigforty's Avatar
It should hold fairly steady. The real test is go out and go wide open while watching the gauge. If the pressure drops more than 10 psi you need a new pump. When my pump went out I was going from 60 psi to 35 psi under WOT.
Old 12-24-2008, 02:59 AM
nemss1's Avatar
couldnt u pull the pump and test it with a car battery? like run 2 wires (positive & negative to the prongs for the fuel pump?
Old 12-24-2008, 08:28 AM
Old Geezer's Avatar
Default Nope..
1. Running it dry will hasten it's demise.
2. All that test would show is, it runs. Without a load, the test is pretty much worthless.
Old 12-24-2008, 02:56 PM
nemss1's Avatar
well my car wont run. i pulled the line before the fuel pump and turned the key...no gas came out. starter fluid makes my car start up. i tried to run the pump off of a battery...nothing
Old 12-27-2008, 06:57 AM
I changed my fuel filter yesterday and it didn't change anything. Also checked the Fuel pressure regulator hose to see if it had any fuel in it or smell like it. It was fine. So, I guess next I'll check the alternator and battery for free at the auto store. Then I'll break down and buy a fuel pressure guage.
Old 12-27-2008, 12:55 PM
nemss1's Avatar
would a bad alternator cause a car not to start???
i replaced the battery...still nothing
Old 12-28-2008, 07:06 AM
That's what somebody over on the truck forum said.
Old 12-28-2008, 02:10 PM
nemss1's Avatar
could a bad alt cause the fuel pump not to turn on?
Old 01-01-2009, 12:33 AM
IDK. This **** is crazy
Old 01-23-2009, 07:58 AM
Fuel Pressure:
At Idle - 50psi
5000 - 44-45 psi
So it is my fuel pump, right? Isn't pressure supposed to increase with rpm or hold steady? I've replaced the battery, belt, and alternator about two weeks ago. So I know it isn't that.
Old 01-24-2009, 08:27 PM
Sigforty's Avatar
Unless the trucks are different you should have around 58 psi.
Quick Reply: How to tell if fuel pump is going bad?
