Common question...head casting numbers and details
Old 12-09-2003, 08:29 AM
GrannySShifting's Avatar
allot of them had numbers shaved on oen side, its on te other
Old 12-14-2003, 10:07 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
After porting & valve job if their any performance difference in an 853 vs 241?
I keep reading there is but never see any hard data to back it up.
Old 12-16-2003, 07:52 AM
2000Firehawk's Avatar
035 = die cast
317 = sand cast
Which is a better casting process ??
Dave
Old 03-21-2004, 12:46 AM
Scott Turvey's Avatar
Originally Posted by 2000Firehawk
035 = die cast
317 = sand cast
Dave
Just noticed this while I was searching for something, and the fact that nobody answered this. Die cast is the "better casting process" from the standpoint it renders a more consistent product.
Old 03-28-2004, 10:23 PM
FASTONE's Avatar
tttttttt!!!!
Old 08-15-2004, 08:33 AM
BOTTLE ROCKET's Avatar
Default head changes
There were two different cc volumes listed for the "806" casting heads;
69cc
66cc
Which of these is correct for these heads?
If it is indeed 69cc, could you mill the heads .025, and use the thinner gaskets to get aroound 10.5-1?
Old 08-15-2004, 05:57 PM
jrp
SN95 Director
jrp's Avatar
69cc
66cc
https://ls1tech.com/forums/advanced-engineering-tech/111207-ls1-head-combustion-chamber-cc-volume-vs-cr.html
Old 08-16-2004, 01:22 AM
FASTONE's Avatar
why didn"t you start a new thread?
Old 08-16-2004, 05:52 PM
If you're referring to ME starting a new thread, It's because it is in THIS thread that the two different CCs are given for the 806 head. I am justing looking to get it clarified.
Old 05-09-2005, 06:40 PM
Dirty 30's Avatar
TTT, What engine has a 554 head casting?
Old 05-19-2005, 12:09 AM
SStrokerAce's Avatar
You should also add the C5R to this... in case somebody wants to know
0005 and 0090 are the two C5R casting numbers.
Old 02-13-2006, 06:33 PM
  #32
Dirty 30's Avatar
TTT, I was looking for some info for some 706 heads that I have.
Does anyone have an upgrade to this thread or atleast update all the info into the first post. THIS THREAD WILL MAKE A GOOD STICKY ALSO!
Old 04-04-2009, 04:08 PM
  #33
usmczmann's Avatar
Default Question concerning performance diff?
I have a 2003 Chevy Suburban with the 706 casting heads on the LM7 5.3ltr and have recently come across some 2000 Corvette LS1 Heads casting 853. The owner is willing to give me the CAM, Lifters, Push Rods, and Full Head Assembly for $275.00. Number one question is, are these heads compatible with my engine without major modifications? Number two question is are they really any better than the 706 series casting other than the slightly larger intake valves?
Thanks,
Z
Originally Posted by Tin Indian
Below is what I have. BTW, you stated that the 933 and 806 97-98 LS1 heads have a stock chamber volume of 69cc. I believe that is actually 66.67cc
__________________________________________________ __
Casting Number 806 or 933
LS1 (Perimeter Bolt)
97-98 5.7L Passenger Car and Corvette
Material: Aluminum
Combustion Chamber Volume: 66.67cc
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 853 or 241
LS1 (Center Bolt)
99-00 5.7L Passenger Car and Corvette (853)
01+ 5.7L Passenger Car and Corvette (241)
Material: Aluminum
Casting Number 243
LS6
01+ 5.7L Corvette
Material: Aluminum
Combustion Chamber Volume: 64.45cc
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
LM4 / LM7
99+ 5.3L Truck
Material: Aluminum
Combustion Chamber Volume: 61.15cc
Intake Valve Diameter: 1.89 inches
Casting Number 852
LR4
99+ 4.8L Truck
Material: Aluminum
Casting Number 317 or 035
LQ9
01+ 6.0L Truck
Material: Aluminum
Combustion Chamber Volume: 71.06cc
Old 09-04-2010, 11:23 PM
  #34
wbb
wbb's Avatar
i hate to beat a dead horse but i'm tradin my 55 chevy for a 99 z that has a 6.0 the heads cast number i believe was 714 ???? is there such a head number ?? thanks
Old 03-11-2011, 08:24 AM
  #35
Joe00SS's Avatar
i have 853 and was going to upgrade to 243 heads but know i wondering since they are so close
LS1 (Center Bolt)
Material: Aluminum
Casting Number 243
LS6
01+ 5.7L Corvette
Material: Aluminum
would it be worth having my heads ported, instead of get 243's
Old 05-26-2011, 10:48 PM
  #36
Camaro34657's Avatar
Good info. My car has 241 heads on it though. Weird for a 2000. Maybe I read something wrong though.
Old 12-31-2011, 02:41 AM
  #37
RedVertTA's Avatar
Great info on this thread. Does anyone know the difference between 862 and 706 castings? The specs shown seem to be the same but there must be a difference otherwise there would be no difference in part number. Could it be the bore diameter?
Old 12-31-2011, 06:51 AM
  #38
wildcamaro's Avatar
You guys forgot 799 heads, which cam on the HO aluminum 5.3s (L33 and LH6)..they are basically the same as ls2 243s. They are also same as ls6 heads just without the lightweight valves.
Old 12-31-2011, 09:44 AM
  #39
moeZ28's Avatar
Several 2000 model cars ended up with 241 heads...especially the ones with later build dates. I have seen a few 2000 model cars in my area that have had 241 heads stock. Just like some 01-02 fbodys got the LS6 block instead of the LS1 block.
Old 02-14-2012, 10:27 PM
  #40
sepsis's Avatar
So if I want 5.3 heads for my LS1 to send off to AI for CNC work, I'd want the 706 castings?
How much would that raise m compression over the stock 241's with a stock size gasket?
EDIT: Also, which vehicles did 799 castings come on?
Quick Reply: Common question...head casting numbers and details
