241 heads vs 243 heads
Old 11-30-2008, 08:14 PM
ItalianZ28Stallion's Avatar
Default 241 heads vs 243 heads
im looking for cheap heads that will add some more power then my 853 heads what should i do. my cam specs are 238/241 609/615. i guess my question is what head will give me more power and will they both bolt right up or will i have to change things?
Old 11-30-2008, 09:16 PM
on2
on2's Avatar
Unported, 243's will make more power. Both will bolt right up.
Old 11-30-2008, 09:45 PM
djsanchez2's Avatar
Slightly more power, but if you are having them ported..... You can save money by going with the 241's. They will cost you $300-400 less, leaving that for the porting which will make them damned near even in terms of flow.
241 = $100-125
243 = $400-500
Hand porting job at a decent shop out here = $300-400
CNC porting from patriot = $600
Most port jobs will flow between 280-300cfm.
Old 12-01-2008, 01:08 PM
snake charmer's Avatar
i just did a bit of touching up on some brand new 243s that were bought for $400 brand new and assembled . the touch up along with intake and headers should yield a good gain .
Old 12-10-2008, 09:20 AM
TheLSgun's Avatar
Where can you get some brand new 243's for 400 or around that price?
I'd be interested.
Old 12-10-2008, 09:24 AM
after dark's Avatar
I am doing the same thing (stock 243's on my 2000 T/A)...Are you going to use OEM head bolts or ARP head bolts?
Old 12-10-2008, 09:32 AM
TheLSgun's Avatar
Where did you get your 243's from?
Old 12-10-2008, 11:08 AM
VIPRETR2's Avatar
Patriot used to sell unported 243s for 4-500 dollars.
Larry
Old 12-12-2008, 03:23 AM
1badrz28's Avatar
deleted found my answer
Old 12-12-2008, 03:48 AM
shaun's Avatar
what year and engine did the 243's come on? i have a 02 longblock in my car and it has 241's on it.
Old 12-12-2008, 05:13 AM
TheLSgun's Avatar
243s are the ls6 heads came on the c5 zo6's. They also came on the ls2 GTO's but i believe the valves, and some other specs are different.
Old 12-12-2008, 11:45 AM
Bad Blu Formula's Avatar
Right. The difference between 243's on an LS6 and ones on an LS2 are that the valves on an LS6 are sodium filled resulting in a lighter valvetrain.
Old 12-12-2008, 02:17 PM
TheLSgun's Avatar
Ahhh. I knew it was something like that. Thanks for the info.
So no one knows where to get 243's?
Old 12-12-2008, 03:32 PM
Shon Herron's Avatar
www.advancedinduction.com
Old 12-12-2008, 09:17 PM
1969mach1's Avatar
LS2 head $320 same as the LS6 head
http://www.sdpc2000.com/product/1257...dAssembly.aspx
Old 12-13-2008, 08:52 AM
TheLSgun's Avatar
Thanks, and if i upgrade the vavles with the hollow stem vavles part # 17801930. Then would they be exactly like stock ls6 heads?
Old 12-13-2008, 09:16 AM
andrew04's Avatar
basically, the c5z had a couple different spring / cam combinations, as the power slightly increased basically every years from 01-04.
Old 12-13-2008, 03:07 PM
1969mach1's Avatar
The hollow stem kit is $182, I wounder if thats for one head or two?
Question #1: Why by used 243 head for $600 when you can buy NEW 243 heads for $640???? I say $600 because thats what I have seen them go for used...
Question #2: the 243 head flow better than the 241 head, both stock.
But what about just spending the money to have the 241's CNC'ed,
both would the performe the same, wouldn't they????
Old 12-13-2008, 06:34 PM
project01ss's Avatar
I just purchased a set of ls2 heads and intake off of a 05 gto for $600...Is that a good deal?
Old 12-13-2008, 06:48 PM
IRONFIST's Avatar
How much of a performance difference are we talking, on a stock LS1, to go from 241's to 243's?
Quick Reply: 241 heads vs 243 heads
