Drag Racing Tech
Powerglide in a LS1. What do ya'll think?
Old 09-22-2003, 01:22 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Default Powerglide in a LS1. What do ya'll think?
I want to put a powerglide in the Hot Rod. This is what I have wanted to do since the switch from a manual to a auto trans.
My Hot Rod is a track only car.
I want the best trans set up I can have. I need to have the car run the number(what ever it is 6.70's to 7.20's 1/8 mile) everytime down the track.
I like the fact that if I put a PG in her I only have to make one shift. This means more consistant runs :p
My trans guy said he can make me a manual shift power glide if I bring him back the turbo 350 that has only 1 pass on it. I will not have to pay any extra money for the glide. He even said he can make the glide use my turbo 350 convertor that only has 1 pass on it.
What do you guys & gals think?
Coach
Old 09-22-2003, 01:31 PM
CHRISPY's Avatar
Default Re: Powerglide in a LS1. What do ya'll think?
You need a couple of things with the glide
transbrake obviously
Probably a little more stall
Probably a little more gear
Nitrous cars tend to like glides as they come off the converter well and the hit isnt as hard.
I personally think you'll be faster with the TH350 off the brake.
Cheers,
Chris
Old 09-22-2003, 01:34 PM
Chris,
No Transbrakes. :p I run in the no electronics class. Footbrake only.
5200 stall, 5.14 gears. I think I have this covered. :p
Coach
Old 09-22-2003, 01:43 PM
CHRISPY's Avatar
hehe perfect you are good to go
Old 09-22-2003, 03:43 PM
GeorgeC's Avatar
The TH350 will be a little quicker, the A2 should make a little more trap speed, but will feel much more "doggish," especially footbraking it...
I had a 'glide behind my ARE 382 for awhile, if you remember. There honestly wasn't much difference in ET. Whatever you do, do not use a stock 1.82 planetary!
Old 09-22-2003, 03:59 PM
chevyguy3's Avatar
if he is willing to make you a glide for the cost of your 350, then it isnt a very stout glide he would be making
also i would not use your 350 converter with the glide. to get the car off the line with a 1.72 first gear you will need some more RPM off the line than what the 350 combo called for (nevermind, just noticed you already have a pretty high stall speed)
personally, i think a glide is the way to go. especially in a high HP car that is hard to control the first few hundred feet
Old 09-22-2003, 06:08 PM
Tom the roofer's Avatar
I have one Coach. I love it.
Dedenbear case, Rossler Pro power glide with a Rossler pro trans brake. 1.96 1st gear with 4.86 gears out back.
Very consistant tranny for bracket racing. I have the PRO Bandit shifter for the power glide but this shifter is challanging to install to say the least. I would use the Pro Ratchet for the power glide if I had to do it over again.
Tom
Old 09-22-2003, 06:35 PM
Thanks guys.
I can't run a transbrake.
I run in no electronics footbrake class.
We are thinking about a 1.83 1st gear.
Coach
Old 09-23-2003, 05:10 AM
v8 ute's Avatar
PowerGlide = boring, they just don't feel quick.
That's my opinion
Old 09-23-2003, 06:10 AM
Frank95z's Avatar
Coach The majority of the big buck footbrake racers use powerglides. When my 4l60e gives me trouble i'm going with a glide. I enjoy the win light on in my lane more than going a little quicker But you'll have to change your sig to Coach 02 A2 Z28. Frank95z
Old 09-23-2003, 06:42 AM
99taws6's Avatar
D@mn you... you stole my idea
Old 09-23-2003, 09:13 AM
Frank,
Thanks man.
I have made up my mind. The sig has been changed!
See ya'll at the Shootout!
Coach
Old 09-23-2003, 08:38 PM
GeorgeC's Avatar
Good luck with the 'glide Coach!
Quick Reply: Powerglide in a LS1. What do ya'll think?
